#11 |
diyAudio Chief Moderator
Positive reg.
#12 |
Negative reg.
#13 |
#14 |
Layout. (Details and copper side etc. tomorrow).
#15 |
diyAudio Moderator Emeritus
Hi Salas and Crt. The symmetrical B1 becomes mature. How about the need for heatsinks on the transistors ?
It's only audio |
#16 |
I have calculated that with 60mA CCS per rail (68R//68R=R1) there is no danger at 10V. 60-17mA per rail times 10V for each shunt element = 430mW each. +/- 17mA runs in the audio circuits. No problem for T0-240 devices like those used.
Crt uses 3X68R in parallel, so about 100mA CCS with his 1.87V Leds, at about 11V (1.87Vf gets him a bit high here too). About 1W then. Nothing burned (50C), but being cautious, he added those: ![]() Just use R1=34R, and no worries. |
#17 |
YES SALAS !!! this one is SUPERB.
and has already kicked my previous symetric b-1 buffer. |
#18 |
I am happy that you like it. Enjoy.
#19 |
slightly oftopic
Is it possible to use just pos shunt reg with original "singleend" B1 ehhh, probably not
#20 |
It is quite comical to see that ( after separating the"symmetrical" thread from the normal B1 thread ) questions about the normal version arise in this thread
It should work but it should be made for the right voltage of standard B1. AFAIK this was discussed in another thread: The simplistic Salas low voltage shunt regulator I just found out that the Search function really works effectively nowadays ! A change for the better.
It's only audio |
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
| Page generated in 0.10336 seconds (74.37% PHP - 25.63% MySQL) with 11 queries |
