Building a symmetrical psu B1 buffer
Old 19th August 2010, 10:01 PM   #1911
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Could it had gremlins produced by turning, going back to the common transformer? Its now the most royal powered fan ever it seems, anyway.
Old 19th August 2010, 10:08 PM   #1912
Malka07 is offline Malka07  England
Yes this Fan should be very Happy...as i am with the sound!!!
Thats what i thought Salas...because the tranformer is shared...and now the gremlins have been cleaned up???
Anyway im HAPPY
Old 19th August 2010, 10:24 PM   #1913
Salas's Avatar
There is a CCS between the fan and the outer loop plus there is much more current shunted than drawn by it to care much of what its motor does. There is improved isolation for sure.
Old 20th August 2010, 04:47 PM   #1914
Today, ive been trying to sort out my ground loop problem...i previously fixed this, by lifting the earth from the chassis, but this was only meant to be a temporary fix. So today after trying numerous things, i found that disconnecting the input grounds from the optivol board, got rid of the loud hum...however when i put my ears up to the speakers i can still hear some buzz from the tweeters and some hum from the woofers (not loud...quiet, but still there) I also got this level of buzz and hum, when the earth was lifted. So there appears to be another problem?? I tried switching the preamp and poweramp on while the cd player was connected but off...and also when the cd player was disconnected...but both times the hum and buzz was still there.
Does anyone have an idea, as to what i can try next?
Alon
Old 20th August 2010, 05:26 PM   #1915
Salas's Avatar
Turn your toroid a bit, does it change anything? If the lift works best in your system, keep it lifted and address security with a pair of yin yang diodes.
Old 20th August 2010, 05:28 PM   #1916
woodturner-fran is offline woodturner-fran  Ireland
And pictures could help a lot too....
Old 20th August 2010, 06:48 PM   #1917
Thanks Salas, i will give that a go...and let you know how it goes.
Woodturner-fran i have some pics on Page 190 Post #1899
Alon
Old 20th August 2010, 06:51 PM   #1918
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I've used a CL60 before here, from earth ground to DCB1 ground plane. No problems. Lifted it can hum with certain stuff connected to it.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 20th August 2010, 07:34 PM   #1919
Thanks Teabag, i have attached a pic, can you tell me which is correct please.
Also if i attach the CL60 should i reconnect the input signal earths???
Alon
Old 20th August 2010, 07:57 PM   #1920
Tea-Bag's Avatar
either side of that yellow would be good I think.
I don't know about the opt-vol, but all my signal grounds go to j1 ground jumperwire. One side of CL-60 to that, other to side that attaches to chassis,and earth ground.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
