Building a symmetrical psu B1 buffer - Page 185 - diyAudio
Old 7th August 2010, 06:11 PM   #1841
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by korben69 View Post
The transformer is a RCore 30VA 2x15v.
Caps are 4700uF/35V Pana 105.
Board is fully stuffed, except inputs and pot.
Is is a Selectronic? Those I have found higher than nominal. Especially if having a slightly hot mains. Please measure the AC on the transformer connector on board. If its actually circa 18VAC then sink the Mosfets and it will be OK.
Old 7th August 2010, 06:26 PM   #1842
Yes Selectronic, 19.4v and 19.5v (15-0-15).
No sinks by now, I've to drill them before.
I can hear the relay clicking when powering on/off, with a little delay.
Cheers
Old 7th August 2010, 06:49 PM   #1843
Salas's Avatar
It is too high, they maybe got some 18-0-18 designated as 15-0-15. Sink at least the CCS Mosfets and it will survive well in normal 68//68 mode.
Old 7th August 2010, 09:21 PM   #1844
I've got 2 other toroidals : 30VA 2x15v and 80VA 2x12V.
I'll try tomorrow, too late now for testing.
The wine we drank with dinner : Pommard 1993 (Bourgogne !!!)
Hope my DCB1 will have the same taste... like flying in heaven
Old 8th August 2010, 05:25 PM   #1845
Default CSS current
Just wondering is it ok to run with CSS below 60mA - 3 LEDs with 20mA, 2mA and 2mA...??
Old 8th August 2010, 05:47 PM   #1846
Second try with a 30VA 2x15v toroidal.
I found now -9.5 and +10.2v at the pins.
-21.7 and +21.4 at the 2x68R.
Is it better ?
Old 8th August 2010, 05:56 PM   #1847
Salas's Avatar
Yes. No more heat on the CCS mosfet than necessary for good enough Vin-Vout.
Old 8th August 2010, 06:00 PM   #1848
Salas's Avatar
The CCS current has nothing to do with LEDS. Has only to do with the setting resistors in the 68//68 places. I would not run it below 40mA per rail.
Old 8th August 2010, 06:34 PM   #1849
Thanks Salas
Mosfets are a little bit hot, I think it's normal as they are not heatsinked.
What measures are required to verify that my DCB1 is Ok ?
Old 8th August 2010, 06:39 PM   #1850
Salas's Avatar
Since the Mosfets run current, see also that you have no bad DC offset on the audio outputs and its good to play.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 02:14 AM
Copyright 1999-2017 diyAudio
