Building a symmetrical psu B1 buffer
Old 15th July 2010, 07:57 PM   #1791
massimo is offline massimo  Italy
Originally Posted by sandbasser View Post
Would it be too much to ask for Post #s instead of Page #s - some folks elect to have more posts per page.
Not diffucult to estimate: from post #1761 to # 1780
Old 15th July 2010, 11:08 PM   #1792
wushuliu is online now wushuliu  United States
wushuliu's Avatar
Just want to say that I spent more time listening to the 'really-damn-hot-rod' (or maybe 'hell-rod'?) last night. It just sounds better to my ears. Much better. Although I did change the output resistors down to 470, the difference in overall clarity, smoothness, etc. was not heard in the 220R or 1k. So unless I luckily hit some sort of sweet spot, the improvement is worth the extra heat. Hope someone else gives it a go to compare.
Old 15th July 2010, 11:34 PM   #1793
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Glo-Rod
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 16th July 2010, 02:41 AM   #1794
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its not your imagination. That is why we aimed Blue will be more ready for extreme sports users.
Old 16th July 2010, 02:57 AM   #1795
wushuliu's Avatar
Ahhh. Speaking of which, is the fact that I only have 2x4700uf - versus the 4x on the Blue Board - an issue with this mod?
Old 16th July 2010, 07:41 AM   #1796
Salas's Avatar
There is strong PSRR and stability in the regs, filtering not an issue as such. Its some users unavoidably will want it all out and far out so its good to be able to experiment with more filtering and TO-220 diode types because there will be anti polar bear energy consumption policies most likely.
Old 16th July 2010, 08:10 AM   #1797
samoloko is offline samoloko  Bulgaria
where can we find updated schematic of Hypno and Blue
Is It schematic from post one - I see other resistor values
Old 16th July 2010, 08:15 AM   #1798
Salas's Avatar
Old 16th July 2010, 12:27 PM   #1799
thx
Old 16th July 2010, 04:28 PM   #1800
korben69 is offline korben69  France
Using a 9V battery and 1k2 protective resistor to feed, and you measure each one's ends for voltage when alight.
Hi Salas
Am I right using this for matching Led's with 1K at Vout ?
(posted before in the wrong thread)
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
