Old 11th July 2010, 07:09 PM   #1701
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Next step is 600mA per side then 2A, for enough perceivable niceness. But 200-250mA is the main chunk. Then up it goes diminishing returns.
P.S. Post in 1024x748 links from now on (don't forget to kill the .th in the link else its thumbnails), the server takes refresh to auto resize, and big photos hinder browsing for people on laptops. I am gonna fix the above pics.
Old 11th July 2010, 07:10 PM   #1702
udailey is offline udailey  United States
Passive Aggressive
Got those big sinks ready?
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 11th July 2010, 07:13 PM   #1703
Salas's Avatar
Hey, you can have your buffer, and the feeling (plus electricity bill) of running an F5 with one move!
Old 11th July 2010, 07:17 PM   #1704
wushuliu's Avatar
How do I check Vout w/ my DMM? Forgot about that part...
Old 11th July 2010, 07:22 PM   #1705
Salas's Avatar
You mean the reg's Vout? You can touch the 3rd pin of the Mosfets nearer to the relay with one probe, the other probe earthed. Or the left most pin of the left audio 2SK then the right most pin of its mate.
Old 11th July 2010, 07:30 PM   #1706
wushuliu's Avatar
Originally Posted by Salas View Post
You mean the reg's Vout? You can touch the 3rd pin of the Mosfet nearer to the relay with one probe, the other probe earthed.
Yes, thanks Salas!
So would any other changes be required to try 600mA aside from larger sinks?
Old 11th July 2010, 07:32 PM   #1707
Salas's Avatar
Just big size sinks. Under 1C/W per pair. You check voltage across Rset and you divide by Rset's value. If it gives 0.6A, then that is what you got.
Old 11th July 2010, 08:05 PM   #1708
pchw is offline pchw  United States
From my experiment, the most noticeable improvement was from 60ma to around 120ma. After that, the only thing that I could feel going up was the temp. So, I settled on 140ma. I also found keeping the FETS too cold didn't sound as good as keeping them at 40C and upward. Mine are at 45C inside the (old external SCSI HD) case.
- Fred -
Old 11th July 2010, 08:10 PM   #1709
regiregi22's Avatar
Originally Posted by wushuliu View Post
Yes, thanks Salas!
I would place bigger resistors. Imagine you are using 10ohm resistors. That's about 250ma, so 0,625w aprox. We use 5w resistors for long term accuracy.
If you use 500ma with a 5ohm resistor, that's about 1.25W. So I will use something bigger than 5w if possible.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 11th July 2010, 08:25 PM   #1710
wushuliu's Avatar
Thanks Reg. I'll stick w/ the 10 ohm then. Doesn't sound like there would be much to gain from going lower.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2013 diyAudio
