Building a symmetrical psu B1 buffer
Old 10th July 2010, 01:28 AM   #1691
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by Salas View Post
You use too small sinks for 10R set resistors, luckily those Mosfets are war dogs.
When they'll land in the case they will be bolted to the alluminum bottom plate, could this be enough?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 10th July 2010, 01:31 AM   #1692
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
By all means. Imagine it copes with now situation. Just don't run it too long for the time being. Nice careful build by the way.
Old 11th July 2010, 11:42 AM   #1693
Malka07 is offline Malka07  England
Yesterday i hotrodded my dcb1...i added a 5w 10ohm resistor to the 1w 68r resistors...giving me when measured 7.9ohm
2.04v/7.9 = 258ma
1.73v/7.9 = 218ma
Wow what an improvement!!! The soundstage has opened up wider and deeper, i am hearing sounds all around me(yes sounds even coming from behind me!!!). As a result i can tell where singers or instruments are very easily, and can even differentiate between backing singers. Now this is what i call Holographic. Detail has also gone up a notch and sounds more dynamic, yet the music never grates, i just want to keep on listening....BUT...
After listening for about 30mins (Yes i could tell all the above with just 30mins of listening!) i checked to see the temperature on the mosfets, by touching them with my finger, OUCH way too hot cant touch it very long before it burns, so i took out some heatsinks from an old computer powersupply that doesnt work and listen again for about 30mins, this time the temperature of the mosfets are cooler then before but still too hot, and there is no way im going back to 60ma after hearing it at circa 200ma!!! So i take out the 12v fan from the computer power supply and connect it to an unused 12v tap on the small toroid. After another 30mins of listening i checked the temperature of the mosfets and they are cool
Next up i will install the fan into the cover of the chassis, and i will try the salas shunt reg to run the Optivol
Special thanks to Salas, Nelson Pass and all who participated to make the DCB1 possible
Old 11th July 2010, 02:05 PM   #1694
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Would be nice to know if theres a limmit (the current) where it starts to sound better,and if itīs an upper limmit where it donīt sound any better..
Old 11th July 2010, 04:21 PM   #1695
R.I.P.
could you hear any difference on the high CCS current whether the FETs were too hot or cool or very warm?
regards Andrew T.
Old 11th July 2010, 06:06 PM   #1696
Hi Andrew, yes i do remember at the time thinking, that they sounded better when the fan was on them, but if it really was better, it would of been a very minimal improvement, maybe cleaner sounding, but not as big an improvement as going from 60ma to 240ma. I should also state that before i went up to 240ma i went to 80ma and did notice an improvement, but again it was slight, but it did improve with the soundstage increasing in depth and width and sounds seeming to float in the room, again more of a 3d sound just not to the extent of going up to 240ma.
Alon
Old 11th July 2010, 06:20 PM   #1697
udailey is offline udailey  United States
Passive Aggressive
F5 uses same transistors.. 1.3A !!
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 11th July 2010, 06:28 PM   #1698
Hmmmm thats got me thinking...How high can i take the current without them getting hot, while the fan is on them
Guess im gonna have to experiment
Alon
Old 11th July 2010, 06:43 PM   #1699
Salas's Avatar
Those Mosfets still amaze me with their ruggedness. So tiny sinks and they survived. Didn't I tell to use proper sinks or bolt to thick floor so many times? You can't run on same sinks you use for regular setting a hot rod. OK, killing a Mosfet is no big deal, but if someone uses a DC amp without output relay DC sense, bye bye speakers. OTOH, when prepared rightly the anti environmental setting attitude has some subjective benefits.
Old 11th July 2010, 07:04 PM   #1700
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Hm. I have 10 ohm Mills for my hot rod. So if I try out 6 or 6.5 ohms, that would make for a sizable increase in mA. Enough to make a noticeable difference I imagine?
I assume 5 ohms is the lowest one should go?
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
