Building a symmetrical psu B1 buffer - Page 169 - diyAudio
Old 9th July 2010, 01:36 AM   #1681
udailey is offline udailey  United States
The Lightspeed is not sensitive to ambient light. I have had mine playing with the top cover off for years. Several different iterations as well. Once in a great while an LDR will not be sealed well. This LDR should just be thrown out or somehow sealed with some goop.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 9th July 2010, 06:23 AM   #1682
Salas
why are you use 470r as gate stopers
Isn't It too high
Old 9th July 2010, 06:44 AM   #1683
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Where, in the regs? That has to do with how I wanted the closed loop gain graph of the dc error amp and what kind of phase margin I got, then with subjective evaluation on the point to point proto. There is no rule of thumb 'small' or 'big' for those.
Old 9th July 2010, 09:41 AM   #1684
william2001's Avatar
kp93300 - I'm using red LED's, and get ~4.85V from the circuit. As Uriah said, these LDR's are sealed. I've not noticed any problems with light from the PS LED's.
Old 9th July 2010, 09:58 AM   #1685
regiregi22's Avatar
Originally Posted by kp93300 View Post
Hi William,
What is the colour LED that you are using ?
I understand that the Lightspeed is sensitive to ambient light . Do you find this a problem with the LEd next to the silonix ?
regards
kp93300
Why are you assuming that? The Silonex devices are potted and isolated from the exterior ambient light. Though I don't know what tolerance it has. I mean, in extreme light conditions it may be affected. But not at all in a closed enclosure.
I don't know if a shunt regulated for the LDRs will give any improvement. After all, it is driving a led. Could be a good experiment to hook up a regulator and checking with a scope if the resistor varies with ripple or whatever
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 9th July 2010, 04:10 PM   #1686
I know its not a Lightspeed thread so maybe we shouldnt be jamming this one up with LDR talk. Why dont you steal power from the incredible regulator thats in the same box???
Yes the quality of the power you feed it is the largest improvement you can make.
Uriah
Old 9th July 2010, 10:57 PM   #1687
Reality first!
ClaveFremen's Avatar
Just to say that finally it's up and running!
In the 'wild' but it's working!
The 10 Ohm resistors are temporary while Mills arrives...
Also the pot (a lightspeed will mount there) and the 100 uF caps are temporary, I'll mount sockets to swap different caps.
In the attached photo is near the 'wild' MyRef.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 9th July 2010, 11:04 PM   #1688
Salas's Avatar
Old 10th July 2010, 12:46 AM   #1689
Reality first!
Another photo then...
the dissy temperature is 63C (room is at 30C...) and it sounds great from the start
AC rails are at 14.4V and the 30VA is warm (35C)
Dario
Old 10th July 2010, 01:13 AM   #1690
Salas's Avatar
You use too small sinks for 10R set resistors, luckily those Mosfets are war dogs.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright 1999-2017 diyAudio
