Building a symmetrical psu B1 buffer
Old 26th June 2010, 09:36 PM   #1601
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes 10R 5W are OK for good current.
Are you sure those films aren't 0.22uF and not 2u2? There is no film cap value that can do harm. It just that some members found Wima 0.22u blending well in the sonic mix.
Your pcb looks nice and orderly BTW.
Old 26th June 2010, 09:47 PM   #1602
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Hi Salas,
these red cuties look just like these:
MKS-2 2,2 Folienkondensatoren, Wima MKS-2
Old 26th June 2010, 09:50 PM   #1603
Salas's Avatar
I thought MKS2XL was over 10uf. They are MKS2 then. 2u2 is fine as well.
Old 26th June 2010, 10:05 PM   #1604
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Yes, they're 2u2 MKS2XL.
Thank you, Salas
Any suggestion regarding the 10 Ohm resitor ?
MOX / Mills / Kiwame /etc.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 26th June 2010, 10:24 PM   #1605
Salas's Avatar
Its not a place that passes anything more critical than DC current. Lowest ppm should be Mills though between those you mentioned. Should keep it the steadiest and the less noisy (of academic consideration here).
Old 27th June 2010, 10:14 AM   #1606
R.I.P.
the PCB has space for 2resistor on top. Two more can be fitted underneath attached to the legs of the top two.
30r will dissipate ~130mW (22% of 600mW).
Three 30r gives the same current as one 10r. and looks far neater.
There is room for a fourth resistor to trim the current to what you want. Any value >=30r can be used for final trimming.
I certainly would not put a bulky multiwatt resistor for setting CCS current.
regards Andrew T.
Old 27th June 2010, 10:56 AM   #1607
oenboek is offline oenboek  Belgium
Found some strange things yesterday and today:
Oscillation:
I got oscillation at about 2.5MHz in both sides of the PS . It was visible everywhere, but with highest amplitude on the 47 Ohm resistor, side of the 2SK170 (see pic 1 lower trace). On the output I had a ripple of 7mvpp. Not audible at all, but on the scope it was visible (see pic 1 upper trace 5mv/div). A higher value of the outputcaps (see later) lowered the amplitude, but didn't make it disappear for 100%. A small cap over base and collector of Q3 stopped the oscillation completely (I guess this lowers the bandwidth of the regulation). I still have no idea where it came from. Maybe from the non-isolated cooling plates of the fets, creating a capacity. I guess to be safe I should put a resistor in series with the cap, but with 10nF it's working stable like a rock now. There is really zero ripple on the PS and on the output. See pic 2 for the location of the cap. On that pic you also see the modif I did to the relais to avoid an extra contact. I checked voltages during start and stop, I don't think the jfet is suffering. I also drilled the holes to have symmetrical connections for the inputs, still have to cut the traces.
Caps:
I did the cap-mod (replacing a 100uF by a small one) too quickly, I replaced the wrong caps . This gave just 100nF at the final buffer position (this low value made the oscillation very visible). Today I moved the 100nF to where they belong, // to the 5 LEDs. I had some unused Mundorf Mcaps 2.2uF hanging around. As 100nF was enough on the output buffer, I tought this 2.2uF should do as well. And indeed, sounds great. Compared to yesterday (with 10nF against oscillation, 100uF on LEDs and 100nF on output), it sounds a lot more open today (10nF, 100nF on LEDs, 2.2uF on output). The difference is big. Yesterday I moved from song to song after 30 seconds of listening, today I listened every song till the end. Maybe I was tired yesterday evening . But it's clear that today the music is more "everywhere" in the room. Yesterday it was closer to the speakers.
Before putting the 10nF for oscillation, and still with 100uF everywhere, the soundstage was a lot smaller. In the meanwhile I cleaned the speaker connections, that could have changed the sound as well.
To be sure about the size of the cap, I put a 270R load on the outputs, and drove the inputs really hard. There was no influence on the PSs at all. I'm confident this value of 2.2uF is enough.
PCB:
Last pic is the pcb, before I solder it in the amp. I used other diodes as I still had those in stock. I also drilled some holes to improve airflow (will not help a lot, but is used in tubes as well. I'm sure I will hear the extra air in the soundstage clearly).
There is a 1M resistor where the 220k should be. That's because I have a 50k pot at the moment. I will change it as soon as I have a new pot installed.
BTW, I read a lot of remarks on the quality of the PCB. I had no issues at all, even after resoldering different components several times. Only the protective film gives a strange small and becomes ugly on some points. And a lot worse: it's really difficult to take pictures.
Old 27th June 2010, 11:22 AM   #1608
Reality first!
Hi Andrew,
effectively the pcb has space for 3 resistors in these positions.
So, If I've understood, the needed power is 600mW and 3x 1/2W resistors in parallel would do the trick, right? (I'm not good with math...)
Anyway the Mills MRA5 is not bigger than a 1W PRP...
Dario
Old 27th June 2010, 01:56 PM   #1609
Salas's Avatar
Originally Posted by oenboek View Post
Caps:
So when you got the 2.5MHz oscillation you just had 100nF across reg's output? And then still a little with 100uF? What ESR?
Plastic output caps are better if someone compensates in the error amp, but it takes experience and an oscilloscope as you know/did.
P.S. I run what you did on LT Spice, it spends enough phase margin without a little ESR in the output cap if with film, so the Cdom is a necessity, and its a juggling act, so its trial n' error as you did. The Cdom eats closed loop gain of course on the other hand. Maybe a 0.33R in series with the 2.2u could save you the Cdom. Then again you have found a good tweak set subjectively and its stable on bench...
P.S.2 The thing with the gate current through audio fets when muting to ground could be if having strong signal on them. Unlikely when someone mutes or shuts down but mentionable.
Old 27th June 2010, 05:49 PM   #1610
Dougie085 is offline Dougie085  United States
Is it possible to build one of these with balanced and S/E inputs and outputs? I have a few things in my system that are balanced like my DAC. My current amp is S/E though and I have some sources that are S/E as well.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
