#1591 |
not politcally affiliated
It sure will. You can use 3v LED's instead.
Mouser pn MV5352 The typical red is 1.8v x 5 = 9v I am not sure if they will be too noisy. Other's may comment on that. I know 12v one's Salas told me are risky.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#1592 |
out of curiousity on 15vdc with salas's shunt reg, possible? anyone can guide me in this? if possible with some calculation too, so that i can learn from you guys
#1593 |
there're several designs up to 60V out and even HV schems up to 300V out for tube freaks.The simplistic Salas low voltage shunt regulator Simplistic Mosfet HV Shunt Regs |
#1594 |
Reality first!
Hello,
I'm in trouble with LED matching... I must have missed something. ![]() I've bought LEDs in v4.3 BOM (Mouser 593-VAOL-3HCE4), and measured forward voltage of each LED fed by a 9V battery and a 1K2 resistor in series (right, isn't it?). Measures varies from 1,901V to 1,910V, in spec according to datasheet (mav 2V froward voltage) but far from the typical 1,8V expected value. ![]() So no way of getting 9V or 5,4V (9,53V and 5,70 are best match) Help!
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#1595 |
diyAudio Chief Moderator
It will be OK. The Vout values will still track with positive somewhat higher as expected and in sweet spot range. Just find 2 similar strings.
#1596 |
I had the same results when matching my leds (same part number). You will get a few more tens of a volt in the supply rails. Nothing to worry about.
Other people in the thread reported to have the same values with the same part number. Regards, Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1597 |
I have red LED from different suppliers that vary between 1.55V and 1.95V.
#1598 | |||
Reality first!
![]() Powered ON soldering iron again... ![]() Quote:
#1599 |
Like mentioned before, it's more important to have two strings have similiar total values than the trying to get lower one's. I am using the yellow one's, and they sit @ 10v.
#1600 |
Reality first!
Well, soldering iron now is powered OFF...
![]() Haargh, my R-Core transformer is still shipping from France... ![]() I've implemented directly last mods, I think... Vref caps are Wima MKS2XL 2,2uF, the value is ok? Is 10 Ohm 5W the right value to replace the 68 Ohm couple? Thanks in advance
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
