Building a symmetrical psu B1 buffer - Page 155 - diyAudio
Old 20th June 2010, 06:16 PM   #1541
udailey is offline udailey  United States
Probably means your preamp trafo
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 20th June 2010, 06:22 PM   #1542
wushuliu's Avatar
Ah, got it. Thanks for the terminal block recommendation.
Old 20th June 2010, 06:29 PM   #1543
regiregi22's Avatar
Hi James.
No, I meant to wire everything to the terminal block. One of those big plastic things with about 6-8 screws in it.
Then attach the terminal block (plastic) to the chassis.
Uriah
Yeah, he hasn't said anything about grounding. He is supposing that you will tie it to the metal chassis.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 20th June 2010, 08:57 PM   #1544
wushuliu's Avatar
Regi
ok, so that I'm on the same page. Line and Neutral go to terminal block and earth grounded to chassis, or are all three tied to the terminal bloc?...
Old 20th June 2010, 09:11 PM   #1545
Either way. You can create a star ground on the terminal block if you like or you can do that on the chassis but you should at some point ground the chassis in case it gets shorted to a live line which would then potentially electrocute you if the chassis were not grounded.
Uriah
Old 20th June 2010, 09:45 PM   #1546
wushuliu's Avatar
Uriah
gotcha. thanks
Old 20th June 2010, 09:46 PM   #1547
a "control" transformer could be one that only powers the ON OFF relays, power to protection and delay circuits, illumination, in fact anything that is not direct audio amplifier.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th June 2010, 09:48 PM   #1548
Live and Neutral to your screw fixing and onward.
Protective Earth wire direct to chassis Safety Earth.
Then you can connect anywhere on the chassis to the Main Audio Ground.
regards Andrew T.
Old 20th June 2010, 10:20 PM   #1549
wushuliu's Avatar
So I've powered up the DCB1. I'm getting -5.3mv right channel, .6mv left channel. I take it that's something's probably not right...
and do I jumper BOTH 600Rs or just the one that says Note? (I have a 12v relay)
Old 20th June 2010, 10:51 PM   #1550
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
They are in parallel. One jumper's all right.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 02:14 AM
Copyright 1999-2017 diyAudio
