Building a symmetrical psu B1 buffer
Old 17th June 2010, 06:55 PM   #1521
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by Malka07 View Post
Thanks Again Andrew and Regiregi22,
Correct me if im wrong, but my understanding is that when resistors are used in parralel, there wattage is added on, so for example a 68r(1 watt)//68r(1 watt)//15r(5 watt) would be equivalent to a 10r(7 watt) resistor???
However im not sure if i correct in this understanding
Alon
With these exact values, you will have a nearly equal disposition. The 15r one is nearly 5 times lower in value than the others (5x15=75), so it will burn 5 times more power. Being the others 1w and this one 5w, you have them almost matched. They will result in a 10r equivalent resistor, with a 7w ratting. I think you'll be fine.
Am I wrong in something?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 17th June 2010, 06:57 PM   #1522
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I beleive they will all dissapate equally I believe, making it effectively a 3Watt max combo.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 17th June 2010, 07:00 PM   #1523
regiregi22's Avatar
They won't, just because they have different values, so they will pass different currents.
It's easy: Power is Current times Voltage. So, having all of them the same voltage applied, what will vary is current. Then, P=VxI, will give you higher wattage consumption.
Just ohm's law.
Old 17th June 2010, 08:07 PM   #1524
Blues is offline Blues  United States
Blues's Avatar
Originally Posted by Blues View Post
Alon,
The power will still be distributed accordingly with the most on the lower resistance as more current is passed.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 18th June 2010, 08:42 AM   #1525
R.I.P.
the best formula for this comparison is P=V^2/R
find the power dissipated by any single resistor across the 2.04V of the CCS.
then total the dissipations for total losses.
regards Andrew T.
Old 18th June 2010, 08:55 AM   #1526
westers151 is offline westers151  United Kingdom
I just wanted to confirm my understanding of what I've read with regards to potentiometer values. Back in post #138 it was said the sweet spot was a 20K pot, but anything between 15K and 25K would work without having to change the 220K resistor value.
Is a 20K pot still considered to be good? I'm looking at pairing the B1 with a ladder attenuator and if a 20K pot is still good then it opens up my choices with regards to sourcing (buy or build myself rather than just building).
Old 18th June 2010, 09:44 AM   #1527
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
20k is good.
Old 18th June 2010, 09:47 AM   #1528
Thanks.
Old 18th June 2010, 10:03 AM   #1529
regiregi22's Avatar
yeah, 20k is still alright. Time has passed by, but the design itself remains the same
Old 18th June 2010, 10:43 PM   #1530
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Hello,
in BOM a 2x12V 50VA transformer is indicated.
Can a 2x12V 30VA R-Core one be suitable?
Thanks in advance
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
