Building a symmetrical psu B1 buffer
Old 16th June 2010, 08:57 PM   #1511
Blues is offline Blues  United States
Blues's Avatar
Alon, I'd like to know your opinion with the LDR volume control when you get around to it. Thanks!
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 16th June 2010, 09:28 PM   #1512
Malka07 is offline Malka07  England
No problem Allan
At the moment i've been using a p2p b1 buffer with Alps blue in shunt mod with tx2575 nude resistors in series(Shunt Pot Volume Control - World-Designs-Forum). Sounds very transparent to me, so this is what i will be comparing the Ldr volume control with dcb1 to. Cant Wait.
Old 17th June 2010, 02:36 AM   #1513
mr.duck is offline mr.duck  United Kingdom
What other JFETs could be used in place of 2SK170? Some not as good alternatives... What specs to look for?
Old 17th June 2010, 02:38 AM   #1514
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Toshiba 2SK117. Sanyo 2SK222 (reverse pin order). Look for -0.5V pinch off @ 6-8mA IDSS. For the audio part lower gm than 170's will up the distortion. If you can solder SMT, use Philips BF862.
Old 17th June 2010, 09:18 AM   #1515
Power (P) = Voltage (V) squared, divided by Resistance (R).
You have 1.73V and 2.04V available to drive the CCS resistors.
The existing 68r dissipate ~ 2.04^2/68 = 61mW. ~10% of maximum power rating of a 600mW resistor.
Add an extra 200r (on the 1.73V side), it will dissipate 15mW, ~3% of maximum rating.
Replace all the 68r and the 200r with a single 20r resistor. Dissipation is now 208mW ~35% of maximum rating. It's going to be warm but reliable.
Try 10r, 416mW ~70% of maximum rating. It's going to run hot, it's value at elevated temperature will be significantly different from it's cold temperature and it may become unreliable.
I prefer to never run any resistor at >50% of maximum rating and in some parts of the circuit <<10% of maximum rating.
regards Andrew T.
Old 17th June 2010, 01:17 PM   #1516
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by Malka07 View Post
Thank Andrew and regiregi22,
When my Ldr's arrive, i will finish up, and then listen to it as is. Let it burn in, and then i will add a 200ohm resistor that i have in my spares to balance the currents and listen for a change...i will then hotrod it and listen again for a change in sound.
When i hotrod, which resistor wattage will i need to use? i currently have 2, 1 watt 68r resistors, would it be ok for example to use???
68r(1 watt)//68r(1 watt)//15r(5 watt) = 10.408
on the 2.04v side...2.04/10.408 = 0.196ma
68r(1 watt)//68r(1 watt)//12r(5 watt) = 8.8696
on the 1.73v side...1.73/8.8696 = 0.195ma
Thanks for your help.
Alon
As a general thumb rule for this project, I recommend a 10ohm resistor per side and 5W rated. That is what I have. They get barely warm, just a bit hot. You could do with 4W resistors, but I wouldn't go lower.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 17th June 2010, 03:41 PM   #1517
To my inexperienced eye, that BF862 looks like an absolute gem!
SMT on that scale should be no problem. Are there any other drawbacks or sonic inferiority compared to 2SK170?
Old 17th June 2010, 04:02 PM   #1518
Salas's Avatar
No. Can be better not worse.
Old 17th June 2010, 06:23 PM   #1519
Thanks Again Andrew and Regiregi22,
Correct me if im wrong, but my understanding is that when resistors are used in parralel, there wattage is added on, so for example a 68r(1 watt)//68r(1 watt)//15r(5 watt) would be equivalent to a 10r(7 watt) resistor???
However im not sure if i correct in this understanding
Alon
Old 17th June 2010, 06:41 PM   #1520
Blues's Avatar
Alon,
The power will still be distributed accordingly with the most on the lower resistance as more current is passed.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 02:14 AM
