Old 6th June 2010, 09:48 PM   #1501
ra7 is offline ra7  United States
I can vouch for the gigawork pot as well. It has been working well so far ~1-2 months :P
I have not had the good fortune of comparing to any of the fancier stepped ones though, and I'm not at all sad that I haven't. The DCB1 is quite stunning as it is.
Old 14th June 2010, 10:36 PM   #1502
william2001's Avatar
I think I'm going to call my DCB1 finished. I took care of my heat issue with more substantial "wings" on the fets. No pics, but easy enough to explain. Same length as Hypnotize, 2.75" tall (full span from bottom to top, and supports the top mesh), and .188" thick. Drilled new mounting holes for the right side buffer to move it further away from the left, and a row of holes between the two buffers in the bottom panel to allow some convection. The whole thing looks mean, and can easily run 24/7 without issue. I'm still very happy with this preamp and want it to last a long time.
Did not attempt to change the R1's again to try and balance the currents as I mentioned before. I've changed these R1's three times already, no lifted pad issues but don't want to push my luck so it will stay as is (10.4 ohms).
I think I prefer the Takman carbon films over the PRP's on the amp feeding my satellite speakers, but I'd have a hard time explaining why. Maybe just a bit more forgiving but still detailed. But close really. Anxious to get started on some other projects, maybe that Toshiba'ed F5 as I have many of the parts already.
Old 14th June 2010, 10:39 PM   #1503
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
May it serve you well a for a long time. A very inspiring build. Congratulations.
Old 14th June 2010, 10:48 PM   #1504
regiregi22's Avatar
Meybe the best DCB1 seen around here, Williams
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 15th June 2010, 04:26 PM   #1505
Malka07 is offline Malka07  England
Default My Dcb1 with Optical volume control
My build is almost coming to an end, just waiting on a few more parts to arrive to finish off...so i thought id take down some measurements.
Negative Rail -10.32v
Voltage across 68r/68r 2.04v
Positive Rail +10.19v
Voltage across 68r/68r 1.73v
Do these voltages seem ok?
Some pics...taken with my phone...so not very good quality, sorry.
Old 15th June 2010, 04:35 PM   #1506
Salas's Avatar
Within normal builds reported range. If you wanna have exact same current on both CCS you can use 56R//56R for the 1.73V side. Now you got 60mA and 50mA. How is your DC offset at audio output? What caps you used for the film cap mod?
Old 15th June 2010, 04:55 PM   #1507
Thanks Salas, I hav'nt measured the dc offsets yet...will get to that soon and report here...Also i will probably not balance the currents yet...as i have a feeling i will be hotrodding and adding some propper heat sinks...but just want to get it up and running, get it burned in, so that i can assess the difference when hotrodded, later. I have done the cap mod, from the start and used 0.22uf Ansar supersounds for this. I have also used Charcroft nude z-foils for input/output resistors
Will keep you all updated.
Alon
Old 16th June 2010, 08:28 AM   #1508
don't remove the 68//68r.
Add an extra parallel resistor to listen to the effect if any.
you have 2.04/34 = 0.06A in the higher voltage polarity.
You have 1.73/34 = 0.0509A in the lower voltage polarity.
Try adding 1.73V / {0.6-0.509} = 190r.
Use 180r or 200r or 220r. Just tack it on the back of the PCB to hear if it has an effect.
Old 16th June 2010, 12:29 PM   #1509
regiregi22's Avatar
Do that just if you want to balance currents on both rails. If you want to hottrod it, you will need to change the resistors for higher wattage ones.
Old 16th June 2010, 05:05 PM   #1510
Thank Andrew and regiregi22,
When my Ldr's arrive, i will finish up, and then listen to it as is. Let it burn in, and then i will add a 200ohm resistor that i have in my spares to balance the currents and listen for a change...i will then hotrod it and listen again for a change in sound.
When i hotrod, which resistor wattage will i need to use? i currently have 2, 1 watt 68r resistors, would it be ok for example to use???
68r(1 watt)//68r(1 watt)//15r(5 watt) = 10.408
on the 2.04v side...2.04/10.408 = 0.196ma
68r(1 watt)//68r(1 watt)//12r(5 watt) = 8.8696
on the 1.73v side...1.73/8.8696 = 0.195ma
Thanks for your help.
Alon
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2013 diyAudio
