#1421 |
Today I reached forward to adjust the volume of the stereo and spark.
A static discharge from my body to the metal knob of the switched attenuator made a sharp "crack" coming from the speakers. I adjusted the volume down and on one channel the woofer cone jumps almost end stop to end stop. If I turn down the source signal, I can hear that the same channel has gone noisy, about 1mVac to 2mVac of substantially white noise (from both woofer and tweeter. Checked the DC at the amp. OK. The DC blocker at the input is doing it's job. Checked the DC at the B1 output. Oh dear, 9mVdc wavering to 10mVdc. Turned the source back on and music plays pretty normally from both channels and hides the white noise. It appears that the B1 jFETs did not like that static discharge and have suffered some damage. I don't know yet whether it's the Source Follower or the CCS that has gone noisy. Maybe both. Any ideas on how to prevent this happening again on the DCB1? |
#1422 |
Lightning In A Bottle
Ground your attenuator knob to a chassis I think is the answer...otherwise discharge yourself somewhere else
Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html |
#1424 |
the attenuator switch is soldered straight into the attenuator PCB. There is only a signal ground on the PCB.
I suppose I could try to find a plastic knob but that is not ideal and will it provide sufficient isolation? |
#1425 | |
#1426 |
Is the knob connected to the signal ground you are telling you have on the PCB? If you, you could try to tie it through a ground breaker with just the diode bridge:
Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1427 |
diyAudio Chief Moderator
You could jam a wire between the threaded neck and body of the attenuator, and connect it to chassis? Is the chassis grounded to main's earth?
#1428 |
#1429 | |
Using the nut & thread might allow a separate wire feed to ground but it would have to be to signal ground. The same arrangement is going to be used in the Mezmerize, as a dedicated pre-amp with remote control. Ah! don't fit any knobs on the outside. Totally remote control. Nah. |
#1430 |
What I have is a pot for my future lightspeed which has the shaft made of plastic. My knob is made of aluminium, but it is isolated from the case and the pot.
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
