Building a symmetrical psu B1 buffer
Old 24th March 2010, 12:42 PM   #1201
R.I.P.
Originally Posted by Salas View Post
Maybe the single ended valve amp creates the sense of bass volume by loose damping factor on the big speaker? Its low impedance too.
yes, tuning of a ported speaker is critically dependant on the source impedance it sees.
This can be from long/short cables and/or thin/thick cables and/or low damping/high damping factor.
Very short cables and high damping factor will sound very different from long cables and low damping factor.
regards Andrew T.
Old 24th March 2010, 01:03 PM   #1202
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its not a simple speaker. Many things could be creating synergy or not, indeed.
Old 24th March 2010, 05:27 PM   #1203
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Thanks Salas for the schematic.
Old 24th March 2010, 06:16 PM   #1204
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Salas, have you been thinking in placing bypass capacitors right next to the transistors of the preamplifier section? I mean the 4x 2SK170. Would it bring any noticeable difference?
I haven't seen it in too much in discrete desings, only in opamps, where they are neccesary. I suppose you will have an explanation for that if you don't put them.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 24th March 2010, 06:44 PM   #1205
Salas's Avatar
You mean small decoupling caps like in op amps psu pins? Not necessary here. Works smoothly as is.
Old 24th March 2010, 07:37 PM   #1206
regiregi22's Avatar
Ok, I suppose it sound as good as it should. Thanks for your fast reply
Old 25th March 2010, 02:10 AM   #1207
dantwomey is offline dantwomey  Canada
Originally Posted by regiregi22 View Post
That's the only thing I am afraid about, the switch contacts. My last rotary switch I bought from ebay fails from time to time. In some positions, you only have sound in one channel, you have to move it a bit to have a good engadgement.
But is not really a concern, it happens only once for every 20 or 30 times I move the switch. And for the price, you can't beat it. An stereo 23 steps switch for 10$, shipping included. I have mine mounted with Dale's and sound wonderful.
dantwomey, I really like your approach. But as you don't need the pots to be good ones, you can use some cheapers. I may do something as you if I is possible to find cheaper motor controlled pots.
Here is a remote control Remote Control DIY kit PCB that is recommended on the very first page of this LightSpeed Attentuator. One caveat though, I have not read the Lightspeed thread so there may be a better solution enclosed.
Dan
Old 25th March 2010, 02:49 AM   #1208
udailey is offline udailey  United States
Passive Aggressive
Maximus has a remote for the Lightspeed. He is on the Lightspeed thread so if you question he will answer. It does not source select, but it does volume and left to right balance and he is a very good power supply designer so I am betting it sounds very good.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 25th March 2010, 07:49 AM   #1209
umut1001 is offline umut1001  Europe
umut1001's Avatar
Hi.I found takamishawa A12W-K 114 relay and 5v omron g6H-2 118 5v relay(could not find 12v)
Does takamishawa suits B1 buffer?Is it better or worse than omron?Thank you
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Old 25th March 2010, 09:14 AM   #1210
khaho is offline khaho  Finland
Takamishawa A12W-K works in my DCB1, but I cannot say if it is worse than Omron.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
