#1181 |
That's the only thing I am afraid about, the switch contacts. My last rotary switch I bought from ebay fails from time to time. In some positions, you only have sound in one channel, you have to move it a bit to have a good engadgement.
But is not really a concern, it happens only once for every 20 or 30 times I move the switch. And for the price, you can't beat it. An stereo 23 steps switch for 10$, shipping included. I have mine mounted with Dale's and sound wonderful. dantwomey, I really like your approach. But as you don't need the pots to be good ones, you can use some cheapers. I may do something as you if I is possible to find cheaper motor controlled pots.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1182 | |
Regards, Dan
#1183 |
Then I will start documenting myself about the different ways of controlling a motor. Never built anything like it. I will have a chat with my dad, an old school microcontroller programmer
#1184 |
Here is remote control for Alps;
eBay.ie: IR CONTROL REMOTE SET f ALPS motorized potentiometer (item 350264537471 end time 11-Apr-10 07:04:44 BST) Not cheap, available with input relay control too, for 100 euro. |
#1185 |
Two Bugs running fine Question: on both the 5 LED's on negative rail light brighter than on the other. How does that come ?? (Out Voltage is 9,7V/10,5V) regards Michael |
#1186 |
diyAudio Chief Moderator
The positive Vref is running more current normally. Not enough to see a marked brightness difference, but I would expect it on the plus Vref Leds if obvious with some Leds.
P.S. Happy listening, and post us pics and experiences, like when going holidays.
#1187 |
so have you built up your DC B1's? anyone compare to B1 sound? how do you like it overall? thx |
#1188 |
Thanks Salas, it's positive rail. You can see on the pic.
Sound is really great. I'll add some P3 coolers next to run at higher current. At the moment it has it's place and I'm sure I would miss the bug much if it runs away ![]() Here two pics, with LSQR2 from analog-forum. |
#1189 |
not politcally affiliated
anyone compared the pink vs red resistors?
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#1190 |
Can someone send me the schematic for the auxiliary circuit portion of the Mesmerize? I mean the time delayed Mute relay and input selection relays portion of the PCB.
Thanks in advance. |
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
