Old 31st May 2009, 04:14 PM   #1
Default Firstwatt F1 to drive Stax
Hey, I'm currently in the process of building a Firstwatt F1 and came across this post: http://www.diyaudio.com/forums/showt...t-133128.html. The thread died out fast however its an idea I hope to pursue. Is it possible to drive electrostatic headphones out of an F1 (or other NP designs)? Has anyone had success doing it? Also does anyone know the procedure for wiring a Stax style electrostatic input? If you have any ideas, thoughts or experiences regarding my conundrum please share them. Thank you.
Mile
Old 31st May 2009, 05:13 PM   #2
DougL is offline DougL  United States
Here are several designs for driving Stax Headphones.
Here is a class A design by Kevin Gilmore A Current-Domain Electrostatic Amplifier for Stax Omega II Headphones
Here is a Tube design that has details for wiring the DIN plugs:
All-Triode Direct-Drive Amps for Electrostatic and Electret Headphones
And this hybrid design: Blue Hawaii Hybrid Electrostatic Amplifier for Stax Omega II Headphones
The load is a 100 pF capacitor, and a 200v pp minimum output is required.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 3rd June 2009, 09:22 PM   #3
Nelson,
How would you design for a 400Vpp swing with a load of up to 150 pF?
I was looking, and a Zen V7 style inductively loaded output stage with a 300V or higher power supply might be feasible. Perhaps Cascode A La Zen V8 to lower the distortion. A tube push pull output transformer might have enough primary inductance for the application.
Av is about 100, so 2 stages are minimum.
While you cab get 300V out of a 18V transformer, its not going to be pretty.
Doug
Old 3rd June 2009, 10:53 PM   #4
The one and only
Nelson Pass's Avatar
We used to have a nice headphone amp for the Stax built out of
tubes by Bruce Moore laying around here (the amp, not Bruce).
I don't know where it went, but he probably built more than one.
I have some nice 1000 volt Jfets, so I would probably use those in
a circuit with balanced output and no feedback.
Old 3rd June 2009, 11:00 PM   #5
1000 Volt Jfets would be the ticket.
Doug
Stax CA-X Preamp EchoWars Solid State 31 26th August 2009 09:48 AM
Stax DA300 thinkbad Solid State 15 23rd October 2005 07:54 PM
Stax SRA-12S ObliVion Solid State 0 12th July 2004 01:29 PM
Stax SRA-12S ObliVion Solid State 0 12th July 2004 01:23 PM
Page generated in 0.08756 seconds (70.73% PHP - 29.27% MySQL) with 10 queries
