Old 14th May 2009, 08:37 AM   #1
revintage's Avatar
Default O.H. Schade(1938) meets MOSFET
Lately there has been quite a few threads covering the work of OH Schade 1938, http://www.clarisonus.com/Archives/T...er%20Tubes.pdf . He showed how a tetrode could get triode characteristics with the help of what he called "inverse-voltage feedback". While working as a triode the efficiency of the tetrode was still kept.
On the left is a tube SE in accordance to his suggestion. It has the same output impedance and distortion characteristics as if it had been triode-strapped but twice the output power! On the right the output device is substituted by a common MOSFET that according to Schades suggestion is feedbacked ca 20dB.
Seeing any similarity with a Zen?
By the use of an IT there is a better chance of getting much better HF-bandwith. The example sims with a -3dB point in the region of 100kHz.
Brgds
Lars
Old 14th May 2009, 08:41 AM   #2
revintage's Avatar
A MOSFET has pentode-like characteristics.
With shunt-feedback(inverse-voltage feedback) applied they change to triode-like.
But this old news for the most of you !
Brgds
Lars
Old 14th May 2009, 03:19 PM   #3
The one and only
Nelson Pass's Avatar
Very Excellent.
Old 15th May 2009, 10:51 AM   #4
revintage's Avatar
Default Letīs Schade the 2SK170
So what happens if we adapt what Schade taught us to a JFET as buffer?
Works like wonders !
Zout below 200ohms, together with low THD and acceptable bandwith (-3dB at well over 200kHz). Zin chosen to 10kohm. With 22kohm/91k bandwith is 100kHz.
But donīt try to a volume-pot at the input! Must be fed from a lowZ source.
Brgds
Lars
Old 15th May 2009, 11:06 AM   #5
MRupp is offline MRupp  Germany
MRupp's Avatar
Very interesting buffer concept, but off course it inverts phase, so where you need this ... and it also looks pretty similar to the buffer in the alephono MC stage
Martin Rupp
Old 15th May 2009, 11:18 AM   #6
revintage's Avatar
Is this a problem? If so, just shift plus and minus on your speaker terminals .
Brgds
Lars
Old 15th May 2009, 12:21 PM   #7
MRupp's Avatar
Not a problem at all (as long as you keep track of the number of times you change phase in your system and do not switch to and fro inverting / non-inverting stages), and it should be useful where you have a requirement to revert phase ....
Martin Rupp
Old 15th May 2009, 06:49 PM   #8
The one and only
Default Re: Letīs Schade the 2SK170
You don't need R10. This circuit works to provide a virtual ground at the
Gate of the JFET, so the input Z is 10 Kohm as shown. Actually you can drive
it with a range of source impedances, and adding a pot as high as 25K should
work fine.
Old 16th May 2009, 12:02 AM   #9
HighZ lowZ, don't matter. As long as its stable with frequency.
It just becomes part of the feedback divider...
There's a nice photo of a curve trace for a similar circuit:
http://www.radiomuseum.org/forum/the...ate_triode.htm
The only difference, Trioderizer gate is battery biased.
A battery could last a long time, if its only biasing gate...
I imagine you would want to bypass with a good cap???
something weird with that link. You have to find it the hard way...
Forum ŧ
Technique, Repair, Restaurtion, Home construction ** ŧ
Home construction and general radio technique ŧ
The Trioderizer - a solid state triode
Old 16th May 2009, 03:40 AM   #10
chinsettawong's Avatar
Very interesting!
Wachara C.
What if O.H. Schade had MOSFETs? Michael Koster Tubes / Valves 30 18th January 2011 02:53 PM
Accurian Sender Repair help 15-1938 wirelessrat Solid State 17 4th January 2009 08:24 PM
1938 Caphart Turntable free! KP11520 Everything Else 0 10th August 2008 02:11 AM
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
Page generated in 0.13479 seconds (73.69% PHP - 26.31% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
