O.H. Schade(1938) meets MOSFET - Page 4 - diyAudio
Old 7th November 2012, 06:10 PM   #31
Originally Posted by avincenty View Post
A BJT
The JFET curves look more like a real triode. The BJT looks extremely linear though.
Thank you avincenty for your interesting results. Did you convert a run of the mill bjt to a new and linear solid state triode? What is the relevance of "extremely linear" in application? I hope it is good if it sounds triodish?
Old 7th November 2012, 06:26 PM   #32
Yes, a 2N3904.
Not sure about how it would sound. I am not really a solid state person, more into tubes, but I'd think that it would have much less distortion and won't have a tube sound.
I think the JFET will have more even harmonics like a triode and would sound more toobie.
Old 7th November 2012, 06:33 PM   #33
Just for fun, I traced some curves for the NTE451 JFET that show the effect of parallel feedback. It indeed works as advertized (on the curve tracer).
Link to video of curves using a potentiometer to vary the amount of feedback
Thanks avincenty for the interesting video. Creative, instructional and showed that one gets a tweakble solid state triode performance! Was feedback from drain to gate increasing as a function of time? Do you have another video like it for bjt to understand its behavior?. Best regards.
Old 7th November 2012, 07:42 PM   #34
I did not video the BJT but the behavior is the same. The more feedback the more vertical the curves get.
Old 7th November 2012, 07:49 PM   #35
Thank you avincenty.
Old 7th November 2012, 08:46 PM   #36
avincenty: Schade feedback concerns itself with a current source amp; also called a transconductance amp [TCA]. Please take a look at the F1 schematic in its service manual at www.firstwatt.com. It is a differential TCA. Mr. Pass used feedback from the drain to the gate of each of the two amplifying MOSFETs. Clearly Schade feedback [inadvertent or not]; which may have sweetened the performance of this amplifier in favor of a triodish sound. Best regards.
Old 7th November 2012, 08:52 PM   #37
AudioMaker.Tech
Michael Rothacher's Avatar
Looks more like voltage divider bias to me. (F1)
Visit AudioMaker.Tech
Old 7th November 2012, 11:55 PM   #38
It is a voltage divider bias. Please note that it also has the signature of Schade feedback of at least the following 3 requirements:
  • MOSFET Q1 [for example] is a current source amplifier.
  • The Gate of Q1 is a summing junction of 2 signals which are out of phase.
  • A feedback resistor is used between the Drain and the Gate of Q1. It generates the out of phase signal which sums with the in-phase input signal at the Gate.
Old 8th November 2012, 12:02 AM   #39
AudioMaker.Tech
Sounds like you've got it all figured out. I'll just move on.
Old 8th November 2012, 12:45 AM   #40
I am a newbee at this fascinating application and learning it . I hope that I am not out of line in my observations. I appreciate your feedback and that of others like wrenchone and Zen Mod. I understand that SIT is a voltage and not a current source amplifier. Thus, it it unclear to me whether Schade Feedback is useful or needed in it to make it behave "more or less triodish" than it already is. Best regards.
What if O.H. Schade had MOSFETs? Michael Koster Tubes / Valves 30 18th January 2011 02:53 PM
Accurian Sender Repair help 15-1938 wirelessrat Solid State 17 4th January 2009 08:24 PM
1938 Caphart Turntable free! KP11520 Everything Else 0 10th August 2008 02:11 AM
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
Copyright 1999-2017 diyAudio
