Adcom GFA-535... Pics... is THIS Stock?? - Page 2 - diyAudio
Old 13th May 2009, 08:47 PM   #11
777funk is offline 777funk  United States
Originally posted by adason
wow, I just noticed the fuses on that thing!!!!!
if that thing blows, it takes everything with it
I would replace those fuses with correct ones if I were you
I had read here on this forum that the B+- fuses to the power transistors can limit the current to them resulting in poor sound quality. Especially with corrosion on the terminals. I read a few people saying that it sounded better with them jumpered. So, that part of the amp is definitely non stock. Good eye! I saw the two red caps and that was what I was wondering about mainly. I'll have to give it a good look over.
My thought on the fuses is what are the chances the power transistors are going to go bad. In the case they do the current will pop the main fuse (hopefully). Most audio amps I've seen don't fuse the power supply to the transistors. So I figured that since the point of this thing is to sound it's best, I'll change parts if something does go.
Old 18th May 2009, 09:29 PM   #12
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
Those caps are on my unit as well (sorry, I'll have to check the schematic later). Those are stock as I bought mine brand new and never modified.
If you go to diyaudioprojects.com, I'm doing a rebuild of the Adcom 535 psu listed in the solid state section of the forums and upgrading my resistors to Dale Vishay, plus replacing all the electrolytics.
Old 19th May 2009, 12:17 AM   #13
sonidos's Avatar
Here's a photo I took before upgrading the resistors, caps, and trimmer.
Old 19th May 2009, 12:52 AM   #14
ostripper's Avatar
Hmmmm , The fuses might be there to prevent a fire hazard , or to keep the phenolic board from actually burning up. My screwdiver recently slipped and instead of having 8 burned OP devices and exploding screwdrivers , just 1 $.70 - 7A fuse was all I needed. If you are worried about a current "bottleneck" at the fuse , a couple of 2200-3300uf/63-80V caps soldered right at the PCB OPS rails will still offer protection while giving a little more headroom.I have a {C-C-fuse-C} setup and can see a .1mv drop right after the fuse , but at the last cap (6800u - on PCB),nothing at all.
Or at least a slightly over-rated fuse would offer "dead- short"
fire /PCB protection.
OS
Old 19th May 2009, 01:37 AM   #15
sonidos's Avatar
I can tell you from experience that those fuses are there if the speakers are shorted!
One of my stepkids, that to this very day has not confessed, but they removed the cables from the speaker binding posts and put the + and - of one channel in contact with each other. I found the cable sitting on the floor. I immediately hooked everything up and the left channel was dead.
I opened up the amp and one of the fuses had blown. Got a replacement and I was back in biz. As you can imagine, I raised holy heck and nobody has touched my stereo since that time.
Old 19th May 2009, 01:17 PM   #16
sonidos's Avatar
Default Adcom 535 schematic
Here's a link to the schematic
diyaudioprojects forum w/schematic
Old 19th May 2009, 06:01 PM   #17
tortello's Avatar
Hello,
could you please post the schematic on this forum?
Many thanks
Marcello
Old 19th May 2009, 06:43 PM   #18
sonidos's Avatar
Hello Marcello,
I'll check with policy on posting schematics for commercial products. The moderator for diyaudioprojects.com was nice enough to permit me to post it on his site and I don't want to violate policy on this board.
If I get the okay, I will post it.
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 09:06 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Pinoy DiY'ers, FT1600 pics..pics dranreb&* Full Range 5 3rd November 2004 10:21 PM
Does someone have pics of a stock Philips CD753 ? 00940 Digital Source 0 15th February 2004 09:11 AM
PICS: GainClone Monoblock pics Rarkov Chip Amps 19 17th April 2003 07:37 AM
Copyright ©1999-2017 diyAudio
