Two Transistor Amplifier
Old 4th May 2009, 02:07 AM   #1
Stinger is offline Stinger  Iran
Default Two Transistor Amplifier
Hi everyone,
Would someone please determine the components values for this simple amplifier?
I need to run it with a 24V battery and also the sound quality isn't important at all!
Thank you in advance
Stinger.
Old 4th May 2009, 02:33 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: Two Transistor Amplifier
That is just too easy.
Old 4th May 2009, 03:11 AM   #3
sawreyrw is offline sawreyrw  United States
R1=30K
R2=2.4K
R3=500
R4=900
R5=100
C1=100uF
C2=100uF
This circuit will have a gain of 10.
Old 4th May 2009, 03:18 AM   #4
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Load?
Old 4th May 2009, 12:29 PM   #5
Well, thanks again for the fast replies.
The load is a 2...4 ohms speaker (2W). What should be the transistors?
Old 27th January 2016, 07:42 PM   #6
JoelM81 is offline JoelM81  United States
How do you calculate the gain? It looks to me as 2 common-emitter circuits connected with the output going back into the first stage to act as negative feedback, which in my simulations leads to more linear amplification than if there were no feedback, right? But I'm trying to do node analysis to find the gain as a function of R3, R4, R5 and not succeeding.
Circuit Wiring Diagrams says the gain is 1+(R4/R5) = (R4 + R5)/R5
Radio-Electronics.com says (R4 + R5)/R4.
So I'm confused, but 1+R4/R5 matches my simulations.
And if it doesn't depend on R3, then how do you set R3?
Old 29th January 2016, 09:50 AM   #7
R.I.P.
You have searched for and found a bad circuit.
It won't drive a 2ohm speaker, properly
2W into 4r0 requires a maximum output of 4Vac and that could be obtained using a supply of 12Vdc, not 24Vdc.
It could be developed into a stage to drive line level signals into a 2k load.
regards Andrew T.
Old 29th January 2016, 11:52 AM   #8
I know it won't drive a speaker. My goal is improved linearity over a common emitter amplifier, and low noise. I was able to work through the analysis and confirm that the AC gain is 1+R4/R5, if beta >> 1.
Some variations are also shown here (but without any explanation), and here (fig 39).
Old 29th January 2016, 12:02 PM   #9
esgigt is offline esgigt  Netherlands
Check Nelson Pass's ZEN amplifiers out... they use FET's instead of transistors.
Old 29th January 2016, 10:08 PM   #10
llwhtt is offline llwhtt  United States
FETs are NOT transistors?
Craig
Two Transistor AmplifierHide this!Advertise here!
OTA - One Transistor Amplifier Mad_K Pass Labs 295 21st October 2015 05:17 PM
PCB's for Leach Amplifier 6 Transistor Svetlana Solid State 3 19th September 2006 08:37 PM
transistor amplifier anton Car Audio 2 12th July 2005 04:08 PM
Transistor Differential Amplifier deesmygal Parts 0 11th November 2004 03:11 AM
