s/500 dual to mono
s/500 dual to mono
Old 21st April 2009, 01:59 PM   #1
joegio is offline joegio  United States
Question s/500 dual to mono
Hi All
I am new to DIY and this is my first post.
I recently built a set of ALPHA-LS speakers (last set available from CSS).
Now I'm off to amplifer selection.
I was woundering if and how a Threshold s/500 could be converted to a mono or bridged configuration.
Joe
Old 23rd April 2009, 06:00 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
s/500 dual to mono
Default Re: s/500 dual to mono
Originally posted by joegio
I was wondering if and how a Threshold s/500 could be converted to a mono or bridged configuration.
If your load is very low impedance, you would consider simply
paralleling the inputs and outputs of the two channels after checking
for similar gain and offset between them.
If you want to bridge, you can either generate balanced signals (the
same signal but with + and - polarity) and feed them into the Left
and Right inputs, placing the speaker across the two (+) outputs
of the amplifier.
If you want to bridge internally, you can do so by feeding the output
of one channel back to the (-) input of the other channel through a
resistor equal in value to the high value feedback resistors used in
the loops of those two channels.
Which of those approaches is attractive to you?
Old 24th April 2009, 04:29 AM   #3
Thank for the detailed options.
I believe the second approach looks to be the simplest and can be accomplished using a preamp with balanced outputs.
Old 27th April 2009, 12:12 AM   #4
It took only a few hours to build an XRL to dual RCA splitter box and I am absolutely stunned by loud a clear my speakers could play.
s/500 dual to monoHide this!Advertise here!
p3a dual mono? Big gain Solid State 19 15th November 2006 10:14 AM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
My Zen V4 Dual Mono wchick Pass Labs 37 11th November 2002 09:54 PM
Single Mono's or Dual Mono? Tazzy Pass Labs 8 3rd October 2002 02:03 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
