Choosing Amps for a 5 Way Active Horn System - Page 3 - diyAudio
Old 22nd April 2009, 07:05 PM   #21
KCCT82 is offline KCCT82  United States
Originally posted by yggdrasil
For your compression drivers I would recommend that you look at F1, F2, F3, Zen 4 or Zen 7. The way I read the manuals on F1/F2 they might be spot on.
For your cone drivers I would look at F5 due to the higher damping. Maybe run balanced F5 on the woofers to get more headroom.
Anyway - it is a long way from zero to five amps. Start by picking one design, make one amp and evaluate before you move on.
Have fun.
Hello Yggdrasil- BIG THANKS, it's nice to have more to choose from, I'll get started on reading Zen amps.
Oh heck it'll be a long way from 0-1! I major in fine art, the farthest possible major from speaker/amp building. Perhaps I should just do the industrial design part
Old 23rd April 2009, 12:43 AM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally posted by KCCT82
I still don't know if F5 will be powerful enough to drive my tapped horns though...
No, I dont think it will
Actually, Im not even sure its good fore your basshorns either
Those are big woofers, and even if high sensitivity, they still need power
Fore woofers, maybe take a look at Earthquakes new amp, the small one, its cheap and quite interesting
But theres also one with built in eq
sometimes we know very little, and sometimes we know too much
Old 23rd April 2009, 01:57 AM   #23
tnargs is offline tnargs  Australia
..... I'm sure you can guess the reason for horns
Actually, I could easily guess wrongly. My reasons for horns don't seem to be the same as yours.
The usual reasons for horns are:
- high SPLs across a big stadium
- reasonable SPLs out of pre-bought or pre-built flea power amps
- pro-horn bias or philosophy
The first two are practical but don't apply to you, and the third is unnecessary, which makes it something you said you want to minimize ...
PS I just noticed you posted in the Pass Labs forum. Is that a restriction you want to see in this thread?
Old 23rd April 2009, 02:15 AM   #24
limono is offline limono  United States
The only reason horns aren't more popular is cost and size but it's such superior topology if done right.
Old 23rd April 2009, 06:06 AM   #25
Hi Tnargs, Limono said it for me... "The only reason horns aren't more popular is cost and size but it's such superior topology if done right." My horn system is where I "maximize", efficiency is what I'm talking about
Umm... yeah please try to stay on amps here, I need the help. The anything goes thread: My DIY 5 Way Active Horn System
That's what I'm trying to prove to myself
Old 23rd April 2009, 06:23 AM   #26
Thanks, I'll take it slowly, probably start with 1 F3 or F5 and see if signal/power is enough for compression drivers, then swap to midbass then tapped horns. Oh, and somewhere in the 6moon review it says the next 3 "F" will be mono blocks, hope they'll suit my need.
Old 24th April 2009, 05:34 PM   #27
DougL is offline DougL  United States
A couple of thoughts from the Peanut Gallery.
Currently, I am running a 3 way Active Open Baffle speaker with a 93 db 8 ohm mid, 2 * 90 db 8 ohm woofers ( 93 db, 2.88 V @ 4 ohms) and a 94 db tweeter.
This runs with 6 channel by 30W class D amp.
I can make my ears ring with this and I have never clipped it.
This is with 4 db of eq for under 60 hz.
Unless you are playing to 10,000 of your closest friends at your local outdoor venue, you probably need less power than I do.
I would not worry about more than 25 watts for any driver.
Several other random thoughts:
F1 through F5 all share the same power supply, and the same general heat sink requirements.
You could build A prototype Case / PS and populate it with any one of the 5 F series, so you could try both the F3 and F5.
Probably easiest to EQ if all 5 amps are identical.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 24th April 2009, 06:19 PM   #28
This runs with 6 channel by 30W class D amp...
Thanks DougL- I'm not sure, but your 30W class D has way more voltage gain than FW amps, right? While 25W is only 5W less than your amps, how will the 10+db less voltage gain affect the outcome? Good tip on the "prototype Case / PS"!
Old 25th April 2009, 12:16 PM   #29
That depends entirely on preamp output.
Old 25th April 2009, 05:52 PM   #30
The Firstwatt voltage amplifiers with the exception of the F4 all have enough gain to reach full output with 2 V rms that a sound card will put out. The DCX2496 is capable of putting out somewhat more than 2 volts rms depending on cabling.
I can assure you that an F1/F2 will also have plenty of gain for a 110 db, 16 ohm driver.
My question to you is, what size is your room and what are your goals?
I aim for 105 db 1 meter for headroom.
Doug
My DIY 5 Way Active Horn System KCCT82 Multi-Way 27 17th January 2016 01:23 PM
Need help choosing op amp for active crossovers and preamp Jonathan Z Solid State 20 1st September 2010 12:49 AM
Need help choosing a driver and a horn design. italynstylion Full Range 27 10th February 2009 01:28 AM
Choosing drivers for LR active crossover goldyrathore Multi-Way 4 24th May 2004 09:36 PM
Help choosing opamp for active filter Alcaid Parts 5 25th February 2004 10:50 PM
Copyright 1999-2017 diyAudio
