Burning Amplifier BA-1
Old 18th May 2013, 03:06 AM   #331
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
That is really great.
Old 23rd November 2013, 11:32 AM   #332
NYCOne is offline NYCOne  United States
Originally Posted by william2001 View Post
Latest incarnation, and maybe last, of this Semisouth bias circuit ... DN2540 cascode (TO-92's, $1.24 @ Mouser) per Walt Jung's Current Regulator's Revisited article in AudioXpress. Rload=100r, Rset=200r trimmer, 300r carbon gate stoppers right at gate pins of the 2540's. 8k series resistor from the top of Rload to the SS gate bus bar, 220r gate stoppers at the gate pins of the power JFETs.
Maybe what I've done here is absolute overkill silly-ness, but it's simple and cheap, and sounds fantastic. Along with a couple of other small changes elsewhere, this is the best sound I've achieved yet. I'm not missing that F5... (PV1.4 = 1.26 X 104 ??? )
I agree with ZM, can you show the current schematic? It would make it a lot easier to follow along.
Old 23rd November 2013, 11:43 AM   #333
Originally Posted by Nelson Pass View Post
They are pure heat. This is a Burning Amp.
You will get a lot more efficiency out of BA#2, which is push-pull
instead of single-ended/constant current source.
If you want more efficiency out of the all-N channel output stages,
we will expect to be doubling the efficiency in a later version.
I'm just re-reading this thread. Did the higher efficiency all N channel see the light of day?
Old 23rd November 2013, 02:11 PM   #334
william2001 is offline william2001  United States
william2001's Avatar
The only big difference between what I've done and the original - is replacing the bias circuit for the upper power FETS with the Cascode Current Source from Walt's article here: http://www.waltjung.org/PDFs/Sources...visit_0409.pdf
I used the circuit on the left of Figure 1. My opinion is this is better suited to the SemiSouth R100 JFETS that I wanted to use.
I made no changes to the front end circuit. And no changes to the bias circuit for the bottom power FETS (still IRFP240's). And my output stage is "2-deep" rather than "6-deep" as shown in the original article. I now use an Aleph J (semi Babelfish) in place of the BA-1 and am enjoying it very much also.
Old 24th November 2013, 04:54 AM   #335
I think your ideas are cool, I just want to make sure I have them right for a try.
You gave up on the 2SK170 CS and the green LEDs with the 2SK117? Is the 240 gone in favor of the Jung Cascode? Even a hand drawn version of your final would be helpful. If not possible, the total changes are:
Remove the IRFP240 completely, add two DN2450 (Cascoded) and Rload=100r, Rset=200r trimmer, 300r carbon gate stoppers right at gate pins of the 2540's. 8k series resistor from the top of Rload to the SS gate bus bar, 220r gate stoppers at the gate pins of the power JFETs?
No other mods (ie my question about the 2SK170 CS and the green LEDs with the 2SK117)?
TIA
Old 24th November 2013, 05:34 AM   #336
You gave up on the 2SK170 CS and the green LEDs with the 2SK117? Even a hand drawn version of your final would be helpful. If not possible, the total changes are:
You added two DN2450 (Cascoded) and Rload=100r, Rset=200r trimmer, 300r carbon gate stoppers right at gate pins of the 2540's. 8k series resistor from the top of Rload to the SS gate bus bar, 220r gate stoppers at the gate pins of the power JFETs?
TIA
I now realize you keep the 240 as one output, but I could benefit from a schematic.
I'm just not good enough to follow what's still in and what's been replaced. I'm not sure if you put the SS or the IRFP240 at the top or bottom. I realize you mentioned the words, I just want to make sure I see the top the same as you.
Working from the NP schematic: did you replace Z201, R213, P202, C209 and R214 and use that to bias the IRFP240 or the SS (top of the circuit), or did you replace R216, R217 C207, Q204, R219, R218, and use the Jung circuit to bias the IRFP240 or the SSR100 (bottom of the circuit)?
Old 25th November 2013, 11:05 PM   #337
I only changed this part of the circuit.. replaced with that circuit I linked to. Those previous iterations with the K170's and LED's and all that were just me experimenting.
This circuit establishes the bias voltage at the gates of the SS R100's. The 8k series resistor I refer to would be at R128.
SemiSouth on top, 240's on bottom. And by "2 deep", I mean I have a matched pair of R100's on top, and a matched pair of 240's on the bottom. My source resistors are .34 ohms (pair of .68 ohm resistors in parallel at each location).
I hope this clears up the confusion. Just be careful and make sure you understand what's going on here if you were going to try this, I wouldn't want to see someone blow their $$$$ JFETS.
Old 26th November 2013, 07:35 PM   #338
Thanks.
I'm just getting back to finishing my J2 clone. Then I'm going to give BA1 a shot. I read a fair amount about the CCS and I'd like to try the R100s in the BA1. I'm hoping to compare the BA1 with SS against J2 and SIT.
Old 27th May 2014, 05:49 AM   #339
damped is offline damped  India
I'm a newbie taking the first tentative steps.
"R201 through 204 form the balanced inputs networks. R201 = R203 and R202 = R204, and the gain is R203/R201."
does not agree with the schematic diagram. Can someone clarify this please?
Old 27th May 2014, 07:27 AM   #340
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you need to be creative , reading Papa's articles ; what's few typos between friends ?
however , according to
that need to be
R201 through 204 form the balanced inputs networks. R201 = R202 and R203 = R204, and the gain is R204/R202
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Burning Amplifier BA-1Hide this!Advertise here!
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
