#21 | |
The one and only
You will get a lot more efficiency out of BA#2, which is push-pull instead of single-ended/constant current source. If you want more efficiency out of the all-N channel output stages, we will expect to be doubling the efficiency in a later version. |
#22 |
diyAudio Editor
One of the reasons the board area is pretty tight is that the shorter chassis is very congested inside compared to t he longer one. - Mainly due to fitting in 4 supply capacitors...
I'm not sure if there ARE any short chassis with all 240 output devices.. Nelson states that with Elna Silmic 10uF radial caps it sounds great- now those would be easy to fit!! What other radial caps are there that people might consider?, and what are their lead spacing and size? |
#23 |
diyAudio Editor
This would be a great design for those that have gotten irf250 mosfets from Nelson over the years at Burning Amp. You would only need 4 or 6 per channel as each 250 is pretty much two 240's in one can...
#24 |
I am waiting with much excitement and anxiety.
That would be a bump, I Think... keep me in the loop. Elwood.
"when you open your mind to the imposible, soon you will find the truth...." |
#25 | |
... would be my consideration. But I could also go with axial caps as you proposed if this is the common agreement. Chris |
#26 |
diyAudio Editor
Clearly cviller intends for it to work with a lot of caps. I think having your suggestion as an option is a good idea.
#27 |
I'm quite sure I have left space for 37.5 pin distance - if not it's a mistake.
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog |
#28 |
diyAudio Editor
He's worried about the width too..
#29 |
diyAudio Editor
WE HAVE CORRECTED THE ARTICLE ![]() Now its Rev. 1.0 as suggested Please check it out........ Thanks for your patience |
#30 | |
![]() - Eric |
| Burning Amplifier BA-2 | Variac | Pass Labs | 1007 | Today 11:52 AM |
| Burning Amplifier BA-1 | Nelson Pass | diyAudio.com Articles | 3 | 24th October 2011 03:53 AM |
| Burning Amplifier BA-2 | Nelson Pass | diyAudio.com Articles | 5 | 14th September 2011 07:11 PM |
| Page generated in 0.10469 seconds (78.67% PHP - 21.33% MySQL) with 11 queries |
