#241 |
just go for it
amplifiers want to be made !
my Papa is smarter than your Nelson ! tnx to |
#242 | |
If you wire the two 100Vac primaries in series and connect them to a 115Vac supply you reduce the transformer to ~300VA. DON'T.
regards Andrew T. |
#243 | |
Perhaps an alternative would be to series regulate it down to the required voltage? It would require a pretty hefty series transistor, I guess.
Townshend Rock III, EAR 834P, Naim CD5i, First Sound Passive Preamp, Pass BA-3, Pass F4, Pi Sevens 5532 Preamp, JBOZ, DIY Silver cables, Open Baffles, DIY subwoofer, GainClone, o2 Headphone Amp |
#244 |
I'm going to keep my BA-3 with its own power supply, so I'm only concerned about power to the output stage and bias boards.
I want to use my 27+27V transformer, which yields about 38V DC. It seems that the extra voltage would not burn the power transistors, but I'm not so sure about the bias boards. Any thoughts?
#245 |
The output stage of BA1 works in pure single-ended.
With 0.58 A per MOSFET (6), the BA1 provides, with ± 32V, 50 watts into 8 ohms, 25 watts into 4 ohms but only 12 of 2 ohms, ... Is there a "small" circuit that could push the output stage in class AB (in the style of the Aleph 0, 0s and 1), for at least 50 watts into 4 ohms and 2. Regards Darry |
| Burning Amplifier BA-2 | Variac | Pass Labs | 1032 | 22nd May 2012 06:54 PM |
| Burning Amplifier BA-1 | Nelson Pass | diyAudio.com Articles | 3 | 24th October 2011 02:53 AM |
| Burning Amplifier BA-2 | Nelson Pass | diyAudio.com Articles | 5 | 14th September 2011 06:11 PM |
| Page generated in 0.08581 seconds (73.65% PHP - 26.35% MySQL) with 11 queries |
