Burning Amplifier BA-1
Old 14th December 2010, 01:14 PM   #211
nightrush is offline nightrush  Germany
nightrush's Avatar
Originally Posted by AndrewT View Post
post205 pic6 shows pairs of wires passing through holes in the aluminium plate.
Take care to ensure all the Flow and all the Return current pass through the same hole !
Thanks Panomaniac.
Uhm, which exactly do you mean? Those black cables passing through the massive panel?
and yeah, thanks for resizing the pictures, I forgot to do this to all of them.
Old 25th March 2011, 05:00 PM   #212
flg is offline flg  United States
flg's Avatar
How many have tried the BA-1 Semisouth modification?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 2nd June 2011, 08:34 PM   #213
JoshK is offline JoshK  Canada
There is a BA-1 SS mod?
Old 2nd June 2011, 10:43 PM   #214
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Myself and Generg have tried it. I used just one SemiSouth R100 and he used 3 or more pairs. I got decent sound out of it. I swapped it out on the mini-A with a better sound (probably more distortion).
I don't think Papa has sanctioned a SS mod to the BA line of amps. I would think a modded front end would be essential.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 3rd June 2011, 01:42 AM   #215
flg's Avatar
well, I typed this responce hours ago before I went out but...
I would guess back in this thread somewhere you could read about useing a SS device as the follower and a Fairchild or IRF device as the current source device. Should be a worthwhile improvement. Ideally I suppose changing out bouth devices could offer even further improvement but I really have no proof or that.
I beleive GenReg may have experimented with a configuration useing the SS part.
Old 3rd June 2011, 04:27 AM   #216
generg is offline generg  Germany
generg's Avatar
Yes I tried....
First I changed only the non-CCS parts to SS and I liked the sound very much, especially voices came in a marvelous new way.
Changing also the CCS to SS I got no clear result, more details, but also some sharp "s" in the voices.
I have no possibility to measure distortion ..... I suppose there was more.....
@tea-bag: yes, I preferred Pumpkin over the original front end, with the flexible concept variac and the others choose this is no problem...
and the First Wtt is......a really First Class PSS Idea
Old 3rd June 2011, 10:22 AM   #217
Tea-Bag's Avatar
Originally Posted by generg View Post
Yes I tried....
That's true, Pumpkin offers some serious drive to be considered for a SS backend. I am using a cascoded front end for the BA-2 to drive bass speakers, offers plenty of grunt. Runs at about 50v.
Someday I will wire by Pumpkin together more permanantly
Old 3rd June 2011, 10:42 AM   #218
buzzforb is offline buzzforb  United States
buzzforb's Avatar
the Semisouth in the front end was a mismatch I suppose, Nelson Pass takes double SJ109 to drive the following SemiS in J2, so the Semisouth R100 replacing IRF610 is not so good.
But placing the SemiS R100 in the signalpath of the outputstage does not seem to be a mismatch, there are many other examples here in the forum with other amps.
But a little expensive for an experiment, maybe you take for a try only two pairs per channel..... but difficult to compare then, less damping, less power might give other results.
From what little i know, finding a way to put a SS (R550 possibly)device in the 610 position stands to yield the greatest difference in sound. The need for dual j109's i believe is related to the input capacitance and the need for more drive current. I had to add parallel fets on the input of my AJ monoblocks to drive the extra fets i was adding to the output. It is interesting that you heard a difference with SS in the output stage. I would of thought being a powerbuffer operating as source follower, it would not have contributed much of its nature to the sound. I always thuoght the sound of the transistor cam largely from its gain and the associated non/linearities of the amplification. In reading the DIY OpAmp article on the Pass site, it seems you stand to gain lower distortion by cascoding the front end. It allows better control over the fets and protects them against any more voltage that may be needed for more power for Vas and ouput stage. I could be wrong across the board. I am new to all this.
Old 3rd June 2011, 11:36 AM   #219
generg's Avatar
Yes, the SemiS R550 could be a possibility to replace IRF610 in the frontend of BA-1, I tried R550 in my Aleph P but I could not here a great difference, to my surprise, I was used that the SS replacement works immediately, but not in this case and I was not clever enough to calculate the input resistor network correctly.....all voltage values got very deviant from the original values, when I reduced the values to a third of original values.
the 610 has still lower input (and output) capacties (135/60) than R550 (170/20) but it might be a try worth! But no comparison to SSR100 (630/100).
Old 16th June 2011, 12:07 AM   #220
toufu is offline toufu  United States
Does the front end need it's own power supply or can I just use one for everything? Thanks.
Burning Amplifier BA-1Hide this!Advertise here!
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
