Burning Amplifier BA-1
Old 6th December 2010, 12:43 PM   #201
generg is offline generg  Germany
generg's Avatar
congratulations.....
I made the same experience concerning BA-1 and BA-2...
and Semisouth R100 in the signalpart, not in the CCS, sounds also very nice...
I am eager to hear your comments F5 versus BA-1.....
and the First Wtt is......a really First Class PSS Idea
Old 11th December 2010, 02:34 AM   #202
Chad is offline Chad  United States
I posted a few pics in the Picture thread. I really like this amp, very smooth sounding.
Genreg,
Would you share a drawing or a picture of how you implemented the Semisouth. I could see that mod on a future front end board.
Next up is an F-5. Probably will do this after the holiday season is over. Then on to a set of speakers.
Chad
Old 11th December 2010, 10:19 AM   #203
generg's Avatar
the Semisouth in the front end was a mismatch I suppose, Nelson Pass takes double SJ109 to drive the following SemiS in J2, so the Semisouth R100 replacing IRF610 is not so good.
But placing the SemiS R100 in the signalpath of the outputstage does not seem to be a mismatch, there are many other examples here in the forum with other amps.
But a little expensive for an experiment, maybe you take for a try only two pairs per channel..... but difficult to compare then, less damping, less power might give other results.
Old 12th December 2010, 09:25 PM   #204
nightrush is offline nightrush  Germany
nightrush's Avatar
Default It's alive!
There's some hum in the psu and the fuse blows sometimes because it's to small, but it works and plays! It was really like plug(&measure)&play!
Only one quick question: Voltage drop over the resistor, where the sense of the negative bias-board is applied, is a bit lower than that over the others, right? V at the sense-resistor was arround 0,62V and all others 0,68V (all measured before fine-tuning the output stage).
Pics tomorrow...
Amazed nightrush
Old 13th December 2010, 08:05 PM   #205
nightrush's Avatar
So, here are some quick shots.
Amp is working with a 10A fuse I found here at the moment, but I will get some smaller ones, 2.2A or so, don't worry.
The (complete) box is getting relatively hot, don't know the exact temperature, but its above 49C (I've got to get some cheap meter for measuring, or maybe i can borrow one from chemics teacher).
If it's really to hot, although I don't think so, I will add some holes in the bottom and top and front and maybe add some small fans.
Best Regards, nightrush
Old 13th December 2010, 08:42 PM   #206
Melon Head is offline Melon Head  Australia
Banned
Very Nice
Old 14th December 2010, 12:11 PM   #207
R.I.P.
Very large download !
Why do you need to send 5.73MB pics?
regards Andrew T.
Old 14th December 2010, 01:00 PM   #208
Pano is offline Pano  United States
Pano's Avatar
images resized for web. Be kind, please resize before posting.
Old 14th December 2010, 01:06 PM   #209
generg's Avatar
Impressive nightrush!
Old 14th December 2010, 01:10 PM   #210
R.I.P.
post205 pic6 shows pairs of wires passing through holes in the aluminium plate.
Take care to ensure all the Flow and all the Return current pass through the same hole !
Thanks Panomaniac.
regards Andrew T.
Burning Amplifier BA-1Hide this!Advertise here!
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
