Burning Amplifier BA-1 - Page 20 - diyAudio
Old 26th October 2010, 11:07 PM   #191
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
me not likee twice shorter pedals , even when I have twice stronger legs
what's amount of 801's impedance modulus nastiness ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...Đ by Mighty ZM
Old 27th October 2010, 06:50 PM   #192
The amount of 801's impedance modulus nastiness.
The sales brochure from the early eighties states that the impedance characteristics (8ohm) over the entire frequency spectrum is nearly flat ..? So for what it's worth..
Concerning the a75 I donīt know this amp. But can see there is clearly an increasing virtuosity in every new amp composition that is released.
The amp must outperform my beard p100. So better dynamics and better mids. And both are already good.
I need to be able to hear which brand and type of strings are used on an acoustic guitar. I need to be able to hear who is the builder of an instrument. a live performance must sound like a live performance. I need to hear the breathing of a musician whilst playing . I need to be able to hear with full dynamics someone accidently hitting a microphonestand during a full cresendo. etc my current set/up has these qualities which i donīt t hear to often in other set/ups
But please help me I have been playing a bit with the Aleph-x calculationsheet on this forum.
If i'm correctly using the sheet it tells me 20 v at the output fets
7amp bias
60% cs
wil give me
81 watts into 8 ohm
145 watts into 4 ohm (lower than 4 ohm things donīt look nice)..
with a total heathsink kw of 0,21 temp will be 80 degrees (little hot maybe)
I think this wonīt be a to bad amp or do i make a mistake (admitted I donīt know the specs of the heathsinks)
regarding the chef the gaar amp. would it be possible to put different more powerfull single ended clas a output stage behind...
By the way the wadia cd player gives 50db of output could that be of help in choosing amp
Old 27th October 2010, 07:27 PM   #193
Zen Mod's Avatar
chef de gaar amp is one niece piece of engineering , and why not - he obviously learned from the finest
you'll not make mistake if you try to make one
there is no need for different output stage , except addition of power resistor , going from output to neg PSU leg - which will bring some SE bias ;
wadia : 50db ; comparing to what ?
Old 4th November 2010, 07:57 PM   #194
Zen mod
A little delayed reply,
Thanks so far for help. Im studying and trying to understand the numbers. Which i feel is nescesarry in order to make the right amp choice. And, for understanding what Im doing later on .
So this means i will probably be comming up with some (relativly simpel) questions soon .....
Just for now, concerning the Wadia 830 it says :
output 50 db in 100 0,5 db steps. output impedance lower than 15 ohm.
On stereophile test they state output voltage 0 to 4,25 volt.
Would this be enough to use only powerstage of ba-1 as is suggested in the article?
or do I need more voltage?
Old 4th November 2010, 08:06 PM   #195
Zen Mod's Avatar
I'm pretty sure it will be enough
Old 4th November 2010, 08:24 PM   #196
nightrush's Avatar
Default Q201 Question
I've got a maybe stupid question regarding Q201...
From what I've figured out so far, Q201 is biased with voltage of around 0.2V between Gate and Source without a signal applied. When a signal is applied, the voltages goes up or down some 0.1 volts or so, thus controling how the current is spread between the two paths to V-.
The only thing I can't figure out is how/why exactly the gate-pin gets fixed at around 0.2V below GND. Is this because of the internal resistance of Q202? And is this resistance really the same in every 2sk170?
I hope you can help me.
BTW: You may not have noticed, but I'm also building this amp...
At the moment, I'm waiting for the cases to be finished. I brought my blueprints to a friend of my father, who owns a metal processing company, but he is a bit slow... On the other hand, I think I can get them nearly for free, only paying for the aluminium...
Of course you'll instantly get some pictures as soon I've packed the boards and stuff inside the cases.
~ nightrush
Old 4th November 2010, 08:35 PM   #197
Makes my live easyer isn't it..
lesser components than other options
Probably most promissing option for optimum sound.
I guess valuable question is if there is any dc comming out of wadia (balanced) outputs
Now how could i get some more power out of this? Bridging or x-ing or.....?
(i want to stay with my 4 2x 18volt 500va transformers
And have about 0,15 kw of heathsink per mono channel available.
Old 4th November 2010, 10:01 PM   #198
Zen Mod's Avatar
~ nightrush
you wanna fish , or yo wanna go fishing ?
go to FIRST WATT HOME and download all pdfs you can find there
same - go to Borbely's Home Page , download all pdfs
read - and few things will be clearer
anyway - I think it's better answer than short "yes"
if you're thinking about more power ........... just go and build Cheff's UP amp
Old 5th November 2010, 02:32 PM   #199
nightrush's Avatar
Hi ZM,
I've already checked Pass Labs and First Watt, but found nothing that could have helped me with my question.
Could you please give a little concreter answer?
How can I calculate the internal resistance of the mosfet? It varies with the varying Vds, which must be above the saturation voltage otherwise the jfet would be no ccs, but I can't calculate this voltage without the internal resistance, or can I? It's like trying to find the end of a circle...
At least this is correct, if I got you right?
Downcast nightrush...
Old 6th December 2010, 02:58 AM   #200
Chad is offline Chad  United States
Finished preflighting my BA-1 tonight. Hooked up the speakers, I love the sound of this single ended amp. This is my first se amp. It sounds very good. I like it more than the BA-2 which sounds great also. I'm using axon caps at the moment. Figure in few weeks I'll put in some silmics and see if I can hear a difference. It took about 45 minutes for the sinks to come to temp and I seem to be able get offset pretty steady around 1 to 2 millivolts after it warms up. Once I tidy up the wiring I'll post some pics.
Next on the list is a F5. Then I'll take amp break and build some type of full-range speaker that will have medium WAF. Kinda waiting for the new Seas ($130) driver Papa's been playing with.
Papa again thank you for sharing your life's work.
Chad
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
Copyright Đ1999-2017 diyAudio
