what to Upgrade, Aleph-X
Old 8th April 2009, 02:39 AM   #11
audiodan is offline audiodan  New Zealand
Thanks Graeme!
here is a photo showing layout. Im sure its causing the problems with offset as the back heatsink heats up more than the rest.
Well with these comments of the changes of the X100 to XJ100 im surprised more people have not done the conversion!
now to get some 2sj74 or 27j109
Cheers
Old 8th April 2009, 08:46 PM   #12
gl is offline gl  United States
Hi Dan,
A very nice job indeed.
Graeme
Old 9th April 2009, 08:50 AM   #13
Well here are the changes.
changes to R46, R47 from 2.2k to 22.2k
changes to R16, R30 from 221 to 221k
removing the 10pf caps
and of course included Jfets
How does it all look to you folks?
Cheers
Old 9th April 2009, 06:57 PM   #14
Hi Dan,
Your schematic appears to be based on one from KK's website. I have never seen any evidence that KK actually built and/or tested any of the circuitry that he puts up on his site.
The Aleph-X is a minimalist circuit. Changing almost any component in the signal path will have some effect on the sound. I would really really strongly recommend that you start with a proven implementation, get that running as published, THEN start to modify things to your own taste or requirements.
The GRollins/Hifizen version is the default standard. The AX100/AX100J has been successfully built by macka and daly41k as well as by me. If I was the only one who had built it I wouldn't have the courage to recommend it. There are also several other experienced, long-time members who have built versions of the original and published their results.
As a practical matter, by the way, it is very difficult to comment on a schematic that has no part designators (such as R1, R2, etc).
Graeme
Old 9th April 2009, 08:33 PM   #15
Hello Graeme
I modified kks to be a copy of the one Macka posted or was it yourself. The only real difference is the output stage, having 3 output parallel Fets instead of the 5 which was shown on the schmatic. As far as KKs design all I can say he has expensive boards.
Thanks for your comments
Cheers
Old 17th April 2009, 10:14 AM   #16
jotom750 is offline jotom750  United Kingdom
Hi.
Just to say, I have a pair of KK’s AX boards (the only higher power AX types I could find) and will probably try to modify these to ‘J’ type (are these among the mods required to take an AX to .5 status ?) . I have built an Aleph 5 using his boards which has worked out well, and if people look at the PassLabs Diy site under gallery, misc amps, and others you will see many examples (not mine yet!) of his boards being used. People seem happy with the results. I would say that, though not the cheapest boards, they are readily available, well documented and his assistance with questions has been very good. They have allowed a novice to upgrade from Denon POA 4400 and learn a lot while doing it. Without his boards I would not have had a ‘Doorway to Pass Heaven’.
Next on the list is a Pass F5 using CViller’s boards. (see below)
Regards.
(When I learn how to post images!!)
Old 23rd April 2009, 08:36 AM   #17
Hello jotom750
Just wondering if ya tried those Jfets yet.
Im still in the stage of finding some fets
Old 23rd April 2009, 05:09 PM   #18
Hi Dan.
Sorry to say I haven’t, next on my list is an F5, then Aleph P1.7. I have AX high power boards (KK’s) but wanted to see what was required to mod them (hopefully to .5 status).
I find most of my parts on EBay. Had good luck so far, some very good U.S. (shipping never a problem) and U.K. suppliers. What are you short of ?
All the best.
Jotom750
Old 23rd April 2009, 05:59 PM   #19
Jozua is offline Jozua  South Africa
Default Looking for the latest version PCB
Hi
I am looking for the latest set of PCB's for the Aleph X amp.
Please contact me if any f you guys have a set to sell. I have the version 1 boards (green) and I am looking for the "red" version.
Jozua
Old 5th May 2009, 09:06 AM   #20
Hello jotom
still trying to source the 2SJ74's, although Mr Pass has recommended another jfet, which I understand is about to be released.
Cheers
what to Upgrade, Aleph-XHide this!Advertise here!
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
