Paper mache horn fabricator
In Zen version 3, Nelson details a power supply. My question is this: can two positive voltage power supplies, such as described in the Zen article, be stacked, piggy-back?
I'm submitting a schematic that I simulated. According to Simetrix, the voltage is smoothed considerably with the second stage. I'm seeking this particular method because I wish to use higher voltage (125v) on my mid-stage mosfets. I'm not very comfortable operating a chip voltage regulator at this extreme.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#2 |
Here's a voltage comparison:
#3 |
I don't think you need to(add a second stage)...try adding zener diodes or increasing the values to get your required voltage. Then try increasing and decreasing the values of C5 and C6.
#4 |
Did you look at the graph?
#5 |
Yes, can you explain it to me!
#6 |
Because the input impedience of the pass mosfet is so darn high
there might be less noise if you replaced the R34 resistor with a ccs and replaced the zener stack with a resistor. No zener = no zener noise. |
#7 |
From my understanding of the circuit (limited) it is a capacitance multiplier, with the zener diodes holding the voltage constant. Is what you created a capacitance multiplier-multiplier.
#8 | |
Hahahaaa.... I think you're right...
#9 | |
The first stage has voltage variations of 0.120 volts, while the second stage only has variations of 0.005 volts.
#10 | |
The zener stack is what holds the voltage constant. Get rid of the zener stack and the voltage varies, yes?
| Bench PS: stacking DC supplies | ErikdeBest | Tubes / Valves | 2 | 6th March 2009 02:00 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| CRC Power Supplies | jleaman | Solid State | 1 | 12th March 2005 05:51 AM |
| Regulated Power Supplies for Low Power Amps | PTL60 | Solid State | 18 | 6th February 2002 06:24 AM |
| Page generated in 0.09558 seconds (75.90% PHP - 24.10% MySQL) with 11 queries |
