#11 |
Thanks, can you simulate the circuit with higher values for C5 and C6 to see what happens?
#12 |
NA
#13 |
yes, get rid of the zeners altogether and your voltage will vary with supply.
#14 | |
Paper mache horn fabricator
The problem with increasing the values of C5 and C6 is that high voltage caps are expensive. I'm trying to keep this thing affordable. If you have a cap in mind that will do the trick, let me know...
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#15 | |
#16 |
No replace r34 with a CCS such as a CCS diode using a 10ma CCS instead of the 15k resistor r34 then select a resistor value to use instead of a zener stack. In this case 10ma across a 4k resistor will give you a 40v across the 4k resistor. In this example
any input voltage between ~43v and ~143v (assuming a 10ma CCs diode with a 100v complience rating) will give 40v across the 4k resistor. |
#17 |
Sounds interesting, Woody. I'll sim it and report back. Any particular CCS configuration?
#18 |
Hello Carpenter, I am looking at your circuit, and also your post about higher voltage caps being expensive. From the circuit, it looks like you are using 220uF caps, I am assuming they are electrolytics. These seems pretty cheap to me. As an example, I checked out Antique Electronic Supplies and they have 220uF caps rated for 300 VDC from Illinois Capacitor for $4.75ea.
Peace, Dave |
#19 |
Hi Dave,
I appreciate your comments and suggestions. The problem with high voltage caps begins when you want high uF values. 220uF isn't too bad, but 20,000 uF gets to be serious business.
#20 |
I did a bit of searching and found reasonably priced 1000uF electrolytics at Digi-Key. Panasonic caps are $3.57 each if I purchase in lots of 10. Quite doable.
The only cap that made a world of difference (according to the sim) was C5 and C2 (I'm re-posting the schematics in case something has changed). I'm filtered down to just a tad over 1mV with a two stage regulator.
| Bench PS: stacking DC supplies | ErikdeBest | Tubes / Valves | 2 | 6th March 2009 02:00 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| CRC Power Supplies | jleaman | Solid State | 1 | 12th March 2005 05:51 AM |
| Regulated Power Supplies for Low Power Amps | PTL60 | Solid State | 18 | 6th February 2002 06:24 AM |
| Page generated in 0.08824 seconds (100.00% PHP - 0% MySQL) with 10 queries |
