High input impedance X circuit
Old 30th March 2009, 07:01 PM   #1
zelter is offline zelter
Question High input impedance X circuit
Hello Guys,
I'm looking for an X-circuit wich offers a high input impedance. All circuits I found up to know in this forum use the inverting inputs of the two individual amplifiers as an input. So I have drawn a circuit that with modified feedback path to free the J-Fet inputs. Very simple question (but maybe difficult to answer) "Is this still a X-circiut?" Curious to see your comments guys.
Best
Zelter
Old 31st March 2009, 12:22 AM   #2
kenpeter is offline kenpeter  United States
What stabilizes the quiescent current in the output totems?
Old 31st March 2009, 06:22 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: High input impedance X circuit
Originally posted by zelter
Is this still a X-circuit?
No. If you introduce an error somewhere and follow it through,
it will not reproduce on the other side in phase.
Not that this isn't a good circuit concept - I have had occasion to
use it and it works fine.
X circuits have limitations on input impedance because the active
input terminals are operated as virtual grounds, kind of like an
inverting input op amp. If you want a really high input impedance,
it's easier to buffer the inputs.
Old 31st March 2009, 06:28 PM   #4
EUVL is offline EUVL  Europe
You can "X" the F5, and it still have high input impedance.
Patrick
Old 31st March 2009, 10:06 PM   #5
The one and only
You can bridge the F5 sharing the feedback loop, but any error on
one side is amplified by the other side and becomes larger instead
of cancelling, so it would not be thought of as X.
High input impedance X circuitHide this!Advertise here!
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 07:49 PM
Low amp Impedance input and high dac output tulip Tubes / Valves 1 30th November 2007 08:24 PM
How high is the input impedance of 'a' jfet transistor? Hans L Parts 2 14th September 2006 02:49 PM
IGC with High input impedance! GregGC Chip Amps 0 30th April 2004 05:03 PM
P3A question: high input impedance sobazz Solid State 1 14th July 2003 05:45 AM
Copyright ©1999-2017 diyAudio
