Hybrid with Nelson topology
Old 24th March 2009, 08:33 PM   #51
kenpeter is offline kenpeter  United States
Rev, this is the wiggle measured at your 007 bias LED.
Funny thing: Cathode bias smooths out into a mostly
normal looking sine with as little as 220uF in parallel.
But this makes the output distort even more ?????
Perhaps I'm just looking at the verge of output stage
clipping, extra gain sends it further over the edge?
Old 24th March 2009, 09:05 PM   #52
revintage is offline revintage
Not so very interesting what mystic things happens at the cathode in Spice as this stage works IRL. Have used it with 6H30, 6N6, 6DJ8, 6C45, with different diode strings that is. Simple and stable, sounds better than resistor/cap in my ears !
Wonder what would happen with not so ideal caps etc.......
Old 24th March 2009, 11:31 PM   #53
More interesting yet, how much LTSpice favors a simple
plate bootstrap over an actual constant current source.
THD comes down from 1.712879% to 1.163536%
Mostly in what previously appeared as-if high order
IMD artifacts...
How much of this "improvement" reflects in reality?
I'm betting the gate noise that drove me crazy
earlier is yet another figment of LTSpice's over-
active imagination.
Old 25th March 2009, 02:40 AM   #54
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
In real circuits I get very little difference between bootstrapping
a resistor vs a current source or bootstrapping a current source,
except for the ability to drive the stage rail-to-rail.
Old 16th April 2009, 12:57 PM   #55
croccodillo is offline croccodillo  Italy
croccodillo's Avatar
Hi all,
I didn't forget the thread, I've been very busy with my job and my real life (a daughter, a wife and a dog don't leave you so much free time...).
I ended up with a new schematic, the one below.
I tried a lot of configuration and circuit arrangement, from common cathode to LTP and beyond... and decided I like the simplicity of the schematic I'm showing you now.
The circuit sims very well, the THD and the FFT looks very fine (at least to me), and is quite simple.
One can remove the feedback and make it even simpler.
Ciao,
Giovanni
In Nomine Libertatis Vincula Edificamus,
In Nomine Veritatis Mendacia Efferimus.
Old 16th April 2009, 12:59 PM   #56
And the LTspice .asc file.
Old 16th April 2009, 03:29 PM   #57
The Mu Follower node at R9 top may have lowest "impedance".
But its asymetrically slewed impedance. Pull-up appears infinite,
but pull down no better than your unaided Triode. I see nothing
in next stage that favors this imbalance of slew.
Why you didn't tap drive from the midpoint of r9? Where the
Aleph becomes an equal truly anti-opposite triode in SEPP?
Six one way, half a dozen the other...
Good job on Q3. Emitter impedance at Q6 (seen as-if a cascode)
low frequencies can't leak through bootstrap, cause now there
isn't any! But think you could have picked a smaller MOSFET with
lower gate charge. Where Q6 emitter impedance may yet droop
on the high frequency end....
I mean, its only a preamp stage. Does a triode really want to
charge and discharge the full gate capacitance of M2 IRFP240
through the Aleph's emitter? Overkill component choice...
I mean, if the purpose of the Aleph was to help this plate drive
the big gate of an M1 IRFP9240, does it make sense to load it
down (through the cascode) with an equal or larger dynamic
burden than the one you just got rid of?
Old 4th May 2009, 03:49 PM   #58
Hi all,
I didn't forget the topic nor the project, I'm simply too busy with my job, my daughter, my wife, my house, my dog...
OK, I found a bunch of IRF122 mosfet in one of my scrapboxes in my garage, so why not to use them for this project?
I can use them as a source follower, they should be good enough for the job.
The only problm is I need a complementary P-channel mosfet or bipolar for the active current source... But do I really need it?
I had a food idea (in my opinion, at least), and realized an output stage that uses only N channel mosfets (2 IRF122), keeping the Nelson Pass Active current topology.
Other advantage is we do not need anymore any bootloader for the ACS mosfet.
Attached LTspice schematic.
Ciao,
Giovanni
Old 4th May 2009, 08:43 PM   #59
Sorry, what I meant was "boot strapped circuit"; I'm a programmer, other than an electronic engineer, so the wrong word...
It simulate very well, even better than myu previous schematics on this thread.
And here is the schematic.
Ciao,
Giovanni
Old 29th May 2009, 03:29 PM   #60
Old thread, but not dead.
I continued in my research, and I ended up with a very simple but very nice amplifier project.
I discarded the source follower and went back to a more "canonical" Aleph output topology... but keeping the input tube.
Added also "a lot" of feedback, and it seems it is worth the effort.
I also moved to a parallel output mosfet topology, which seems to lower the THD.
The circuit below simulates amazingly well in LTspice (better than the original Aleph Mini, actually); I'm now in the process of building one prototype, just to test it.
I redrawn the circuit with Eagle, and now I'm drawing a PCB I can build the prototype on.
I will let you know how it will work in real world.
Ciao ciao
Hybrid with Nelson topologyHide this!Advertise here!
SR-1, Bravissimo Nelson 6BX7GT Pass Labs 2 9th July 2009 08:54 PM
Thank you Nelson kilowattski Pass Labs 19 28th July 2008 03:20 AM
Thanks Nelson tedr Pass Labs 1 18th January 2008 06:15 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Nelson Stefano Pass Labs 28 9th May 2003 05:32 AM
