Am I doing something wrong here? It works just OK and with random unmatched JFets, I read 0.09VDC at the output. I think I can decrease this number one way or another, maybe with matched JFets? I'm a novice DIYer, any comment is appreciated. BTW what maximum voltage swing can B1 accept? Cheers, Chul
#2 | |
put trimmer pot between jfets , and take output from wiper let them cook for a while , then adjust exact 0 at output use 47R trimmer pot max swing ........ say - enough ........ ( at least overall PSU voltage , decreased by ..... say ........ 3 V )
my Papa is smarter than your Nelson ! tnx to |
#3 |
Just 50ohm pot. Thank you for the tip
I am planning to use this B1 in the linestage using old vacuum tube that suffers from high Rp and Zout. This way I don't even leave the 0.09V which affect little in the tube circuit. But 3V swing may not enough...Should I use increase the voltage to 12V? Chul
#4 |
#5 | |
I meant PSUvoltage - few volts ;
#6 |
Hi Patrick,
Thank you for the links. At least I now know I did not do something harmfull to my audio.. Cheers, Chul
#7 |
#8 | |
The one and only
50 ohm pot on the Source to Ground of Q101. This would allow you to set the current of Q100 at its Idss value which will give 0V offset.
#9 |
It's nice to hear from the one and only..
I'm the guy who sent AER driver the other day.. Cheers
#10 |
The one and only
How are you doing with those AER's?
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Continental Capacitors' "Type-A" oil-filled capacitors? | radical | Parts | 0 | 21st October 2004 08:39 PM |
| Oil capacitors | Praudio | Swap Meet | 3 | 7th October 2003 03:00 AM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.10721 seconds (83.33% PHP - 16.67% MySQL) with 11 queries |
