#121 |
+/-9V is the supply voltage I used for checking to see if an increase in supply voltage would help anything. This is when I noted an increase in susceptibility to oscillation.
#122 |
Hang in there, I should be able to get mine built and tested soon. My local situation has played out, and I should have some decent time to give to this.
BTW, I also have a 3562A here, and me thinks there is a problem in your setup. The Frequency response plot should be a ruler flat straight line at high frequencies. Do you have the user guide for it? I have a built B1 for comparison as well. No oscillation so far. Bob |
#123 |
That I understood, but with proper decoupling, oscillation is not a problem, and you might probably see less distortion for the same voltage swing, because of more headroom in Vds. The same applies to the reduction is DC offset. Best distortion cancellation will occur when the upper and lower JFETs see the same Vds. And I have given you hints how to adjust that, given your imperfect matching. Patrick |
#124 |
http://www.diyaudio.com/forums/showt...75#post1861675
For those who would not just take my word, someome has taken the plunge and found the BF862 "sounding better than the 2SK170 in the same topology". Patrick |
#125 |
Patrick, you mention a use case of SK filters. Do you have a version with differential inputs?
#126 |
If you want to use opamps that you can use one of these :
http://ntur.lib.ntu.edu.tw/retrieve/173979/02.pdf http://dspace.thapar.edu:8080/dspace.../1/6040411.pdf No idea how to do a differential amp without feedback in a source follower. Patrick
xen-audio.com |
#127 |
sorry to resurrect a thread from so long ago,
if we wanted to build a complete pre amp based around this, in the style of the B1, what else is recommended, local decoupling- no problem. how about recommended rail voltage? would the BF862 work dropped straight into the B1 circuit? |
#128 | |
Sam |
#129 |
See :
Joachim Gerhard Filter Buffer for ES9022 for an updated, higher-performance, cascoded BF862 buffer. Patrick
xen-audio.com |
| This is the DHR.... Dx High Resolution Turbo | destroyer X | Solid State | 914 | 30th December 2012 01:59 PM |
| Group buy for DHR Turbo PCB | Vivek | Parts | 0 | 12th January 2009 10:45 AM |
