#11 |
Measure Vbe (voltage between base and emitter) of ZTXs, not the base voltage per se, although it won't hurt.
Non é mai abbastanza... |
#12 |
also check that you have 4-5v between E-C at Q4
#13 |
O.K.
top view ( o represents pins ) Q5 o 4.62V o 3.9V o 0.64V Q4 o 5V o 4V o 0.6V not shure but this should be like when woching from component side c e b whell it looks diferent when I post, so if I'm right bouth have around 0.6V betwin b and e, and 5 or 4.6 be twin c and e. |
#14 |
yoke , it's useless ( at least to me ) to post without known nomenclature ;
use this schematic , and just disregard part names on pcb ; I know ( and have in my PC ) too much Aleph schematics , to even remotely be sure what you're talking about , without exact schematic ... I hope it will help
my Papa is smarter than your Nelson ! tnx to |
#15 | |
there are several schematic of Aleph30 with diferent markings... and it's been a while since I build this ;-) lets resume power is +/-22V I have around 13V on the output R11 - 5V R14 - 2,5V Z5 - 9V Q5 - from c to e 4.6V from b to e 0.6V Q4 - from c to e 5V from b to e 0.6V Q 6-8 source resistors 0.5V Q 9-11 source resistors 1V |
#16 |
something is wrong
you can't have in same time 2V5 across R14 , and 5V across c-e of Q4 what value of source resistors you have , and how many output pairs ?
#17 |
you are right - I have problems indetifaing resistors but voiltage is 5V on ztx
I have 2 x 3mosfets (just like original) and source resistors are 0.5Ohm |
#18 |
in my xperience ( lifetime as repair techie ....... lousy one
) - fastest and most convenient way of repair - for simple circs as A30 is - is simply to pull out ( ONE BY ONE , to ensure possible mixing ) all semis desolder it , pull out , measure if good - solder it back , if suspicious - replace , if broken - replace check input LTP ( both IRF9610) , for start ; what WAS initial current through outputs - when you made amps ? to me - seems that even 0V5 across each source resistor is on highish side ...... not to mention 1V ..........
#19 |
Yes it seams that would do the trick...resolder everything...
The thing is that I can't keep amp on for a more than a fiew sec since the side with 1V on source resistors start to smell ;-) so I have to turn it on and off... About voltage on source resistors, 0.5V is normal....I think it drops to 0.45 once the amp heat's up. I think that this 0.25V on original shematic is wrong. It should be like 0.5V. 1V is to much and I have to find out what is cosing it. will try to mesure some voltage over input pair of mosfets. |
| voltage on the 1st cap of the aleph-p 1.7 power supply | jarthel | Pass Labs | 15 | 23rd October 2007 09:10 AM |
| Diodes on power supply output for voltage drop? | bst | Tubes / Valves | 7 | 12th July 2007 03:54 PM |
| Half bridge smps voltage drop problem | alexclaire | Power Supplies | 64 | 29th March 2006 03:52 PM |
| tailor output voltage of power supply | Evaas | Solid State | 15 | 28th April 2001 06:55 PM |
| Page generated in 0.11722 seconds (76.11% PHP - 23.89% MySQL) with 11 queries |
