Possible improvements for Aleph?
Old 18th March 2009, 09:38 PM   #21
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I just know there's going to be a point to this...
Old 19th March 2009, 05:34 PM   #22
kenpeter is offline kenpeter  United States
I thought the point was merely to keep you entertained?
I was actually about to make a point regarding the mirrors.
But I'm afraid my mind has gone and wandered off again in
another direction. Something cool enough it might just be
worth the temporary distraction. We'll get back to it soon.
Born of several nutty ideas tossed about this tube thread:
http://www.diyaudio.com/forums/showt...hreadid=140699
Aleph with DC servo!
At DC, its a voltage source.
At subsonic, its a Gyrator
of increasing inductance.
Above 20Hz, its an Aleph.
Go figure...
Old 19th March 2009, 06:19 PM   #23
The one and only
You're not done yet. I still have some you haven't listed.
Old 20th March 2009, 05:21 PM   #24
Allrighty then, a Challenge!
Does your magic bag of tricks contain this one?
Old 20th March 2009, 05:26 PM   #25
Obvious compromise made in the upper right corner.
Wringing what I can out of LTSpice's default libraries.
Better matched compliments would certainly help.
File Type: zip ecalephs1.zip (935 Bytes, 34 views)
Old 20th March 2009, 08:24 PM   #26
The one and only
Yes it does.
Old 20th March 2009, 08:56 PM   #27
Outside the context of abusing 200mV offset chip amps?
I can't find the link now. Not 100% certain that was you.
Maybe just something you had commented on. I don't recall.
Been driving myself crazy trying to follow long ago moved
or otherwise not functioning Pass links posted in forums.
I'm largely having to re-invent the old wheels over again.
Whatever, its entertaining...
Old 21st March 2009, 01:56 PM   #28
revintage is offline revintage
So when you are into complemantary solutions:
Why donīt do it all MOSFET in Jung style.
Old 23rd March 2009, 05:16 PM   #29
Cause I can't predict the VGS-ON of any specified MOSFET.
Much less that any random pair are going to match well.
VBE-ON of Transistor (or Aleph) is much more repeatable.
My design above is already obsolete. I'll soon show you
exactly what I have changed, and more importantly: why.
But I got 150 Class-D amps and a few trays of DSP eval
modules waiting on me to push em thru the test bench.
And thats assuming none of em decide to fight back.
I don't know if I'll get enough of a break at work today
to revisit the Aleph. But maybe sometime this week.
Old 23rd March 2009, 06:13 PM   #30
This drawing isn't clean as I wanted to show it.
But will have to do for now... Time is short.
The emitter coupled Aleph is a base follower,
not a source follower. And the voltage gap
between bases can be partially spanned by
other voltage drops besides Iq set resistors.
Schottkys here tighten the damping factor.
In the old drawing: currents into the gates
look like dErAnGeD squiggles, not sines...
The collectors were overshooting the mark,
and the local feedback was not helped by
bigger gate or base stoppers, nor extra
miller cap.
R3 and R10 are new. They put the bipolars
into a zenlike state without the miller cap's
phase shift. And the gate currents now look
like clean sines through the full audio range.
High order artifacts in the output FFT have
been quieted down considerably.
This added control also makes it possible to
smoothly shut off either gate without the
transistor overreacting. Before, they would
latch into deep saturation. Overdraining the
gates, making them harder to recharge later.
To show what I'm talking about:
I've deliberately biased this one into Class AB.
Sim this one, how smooth the crossover is!
Would have made a total mess before...
The portion of Zen voltage drop on the base
resistors also contributes to the 1.3V base to
base voltage gap. With some further tweaking,
the Schottky drops might not be necessary.
This is not optimized, I don't even know if the
MOSFETs specified in the sim are power types...
Possible improvements for Aleph?Hide this!Advertise here!
Improvements to first GC hotscot Chip Amps 1 26th December 2008 07:09 AM
