#31 |
What, if anything, can be done to make the circuit more compatible with 300 ohm HD-600's?
Scott... |
#32 |
If it is not loud enough for you coming directly from a source (e.g. CD player), then you might want to add a gain stage like a single ended version of the Blowtorch. Just use the +ve output alone and ground the -ve input.
Patrick |
#33 |
Thank you, Patrick.
So it's just a matter of ensuring that there's enough voltage for the headphones? Scott... |
#34 |
You first need to decide how much SPL you need from the phones.
Then the datasheet of the phone will tell you the sensiticity, which allows you to convert SPL to voltage. A typical CD player without volume control will output 2V rms max. If 2Vrms is not sufficient to give you the SPL you want, then you need voltage amplification. The DAO is a follower with (slightly less than) unity gain. It gives you lots and lots of current with very little distortion, but it will only follow the voltage at the input about 1:1. The easiest way to determine whether you need additional voltage amplification is to connect a 10k log pot and a simple opamp circuit of say +10x gain using e.g. an OPA2604 or OPA2132 (for stereo) supplied by 2x 12V batteries. If this is too loud, then lower the gain of the opamp circuit until it reaches the right level for you, including the amount of volume control you need. The you know for sure how much (if any) voltage gain you need, and only then you choose the voltage gain block circuit. The output (current gain) stage is the DAO, already done for you. Patrick |
#35 |
Got it. Thanks again for the clear explanation.
Scott... |
| MC headamp with opa | PTSOUNDLAB | Analog Line Level | 1 | 11th January 2008 09:56 PM |
| Downscaling ZV9? | panos29 | Pass Labs | 5 | 27th April 2006 12:03 PM |
| Downscaling resistor values? | Mick_F | Chip Amps | 5 | 2nd November 2005 10:53 AM |
| Picolino downscaling | 4real | Full Range | 28 | 2nd December 2004 07:54 AM |
| Pico Lino downscaling | 4real | Multi-Way | 4 | 7th November 2004 10:32 AM |
| Page generated in 0.06796 seconds (82.94% PHP - 17.06% MySQL) with 11 queries |
