JFET's ready for abuse
Old 3rd March 2009, 07:03 PM   #31
JimT is offline JimT  Canada
Which jfet is that?
Jim
Old 3rd March 2009, 07:04 PM   #32
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
On F3's I use just grease and anodizing for the JFET.
Old 3rd March 2009, 07:27 PM   #33
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by JimT
Which jfet is that?
Jim
A LU1014-Magura
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 3rd March 2009, 07:30 PM   #34
Magura's Avatar
Originally posted by Zen Mod
well - I meant on that ....... but seems that short circuit between headphones of mine was shorter than usual .......
same question ........ ?
Phase change material, RS stocks it, Bergquist makes it. Nice to work with, works very well.
Magura
DISCLAIMER: I gave an answer to what I believe the question is.
Old 3rd March 2009, 07:34 PM   #35
Magura's Avatar
Originally posted by flg
Thickness?
Because I've only found 0.0015". Actually it was a while ago maybe it was 0.005" At 5000V/.001" dielectric strength, the thinner the better as long as you've checked for burrs and high spots etc.!
Why not use Kapton as the dielectric in your Quasi T-Clad developement project? It's high temp. It even comes with tape goo from Office Depot. Maybe you can get good high temp goo and make real High Performance thermal substrates. I'ld respond by e-mail but I've had to shift gears and think about all that T-Clad stuff in order to respond with a good answer...
While I'm thinkin 'bout it. I think you would have reasonable reliability (real good for the Magura/C/W normal levels) starting at 10W and possibly as high as 20W for that device. N.P. suggests 10W as a max? I would say 20W. N.P. also talks about the Vds vs Ids and load line linearity. That is where 2-3Vds is important. If your doin 10-20W at 3V thats 3.5-6+ Amps. This aint an F3 clone
But what could it be???
I can't remember how thick the Kapton film I have is, I bought it long ago.
Yeah, I see you get the picture of where I'm heading
Kapton will though not be an option, as the thermal cycling will be a deal breaker.
Magura
Old 4th March 2009, 02:53 AM   #36
dave_gerecke is offline dave_gerecke  United States
Hey Magura, What about Mica between the primary copper heat spreader and the main heatsink? I may be wrong, but I seem to remember that mica is a better heat conductor and better electrical insulator than most of the synthetic insulator materials. Only thing that is an issue is that it's hard to get nice flat, planar pieces of mica.
Peace,
Dave
P.S. you could also go synthetic diamond, but that might move the cost up just a bit.
Old 22nd March 2009, 10:50 PM   #37
udailey is offline udailey  United States
Passive Aggressive
So what type of screw/bolt are you using? Nylon?
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 22nd March 2009, 11:09 PM   #38
Magura's Avatar
Uriah
Plain steel bolts. Isolation is sorted out by a shoulder washer.
Magura
Old 23rd March 2009, 12:38 AM   #39
Passive Aggressive
Right on. Thanks for the reply.
Uriah
Old 24th March 2009, 11:01 PM   #40
jupiterjune is offline jupiterjune  United States
Thickness?
McMaster has .002 thick "thermally conductive" Kapton. Has anyone tried this? I was considering getting a sheet for my next amp (if the design is ever published.....).
They have other thicknesses available in the "electrically conductive" variety, but I'm guessing this is not what you want.
JJ
JFET's ready for abuseHide this!Advertise here!
LM3875 abuse vulnerability Puffin Chip Amps 9 14th December 2008 12:46 PM
looking for methods to abuse amps east electronics Solid State 34 31st July 2008 05:39 PM
Reporting an abuse caused Thread Close? jkeny Everything Else 6 20th April 2008 06:50 AM
My wacky budget n00bie 3-way thread. Abuse wanted! Spasticteapot Multi-Way 1 5th January 2007 12:17 AM
sample policy abuse mirlo Parts 1 19th December 2006 05:41 AM
