JFET's ready for abuse
Old 25th February 2009, 04:39 PM   #21
woody is offline woody
Magura, those sure are nice. I however l don't intend to
push mine hard only ~8 or 9 w or so. So I decided to salvage a couple of blown itfp240 mosfets and remove almost all the plastic.
Then sand the dead active device off exposing the copper base
and solder the jfet there. I hope the indium solder that melts
at ~97 c doesn't melt when I use the devices! I put a healthy
Irf260p in the picture besides my soldered Jfet.
Old 25th February 2009, 07:03 PM   #22
Magura is offline Magura  Denmark
Magura's Avatar
97C may be a little on the low side, but time will tell.
I decided against low temp solder, in order to be able to abuse them
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 28th February 2009, 09:17 PM   #23
Magura's Avatar
Originally posted by flg
I haven't tried any soldering on these JFETs yet but on a daily basis I do such things with similar devices to heavy copper PCBs.
Please drop me an eamil, as I can't mail you.
Magura
Old 1st March 2009, 07:03 AM   #24
flg is offline flg  United States
flg's Avatar
Done
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 2nd March 2009, 08:05 PM   #25
Does anyone know the thermal resistance of that device from
case to heatsink?
Old 3rd March 2009, 03:46 PM   #26
Magura's Avatar
case to heatsink?
Of the JFET itself, or the ones I made?
Magura
Old 3rd March 2009, 03:50 PM   #27
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Magura
ya have source of teflon tape , adequate for your "devices"
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd March 2009, 05:16 PM   #28
Magura's Avatar
No, I use Kapton film
Magura
Old 3rd March 2009, 05:40 PM   #29
flg's Avatar
Magura
Thickness?
Because I've only found 0.0015". Actually it was a while ago maybe it was 0.005" At 5000V/.001" dielectric strength, the thinner the better as long as you've checked for burrs and high spots etc.!
Why not use Kapton as the dielectric in your Quasi T-Clad developement project? It's high temp. It even comes with tape goo from Office Depot. Maybe you can get good high temp goo and make real High Performance thermal substrates. I'ld respond by e-mail but I've had to shift gears and think about all that T-Clad stuff in order to respond with a good answer...
While I'm thinkin 'bout it. I think you would have reasonable reliability (real good for the Magura/C/W normal levels) starting at 10W and possibly as high as 20W for that device. N.P. suggests 10W as a max? I would say 20W. N.P. also talks about the Vds vs Ids and load line linearity. That is where 2-3Vds is important. If your doin 10-20W at 3V thats 3.5-6+ Amps. This aint an F3 clone
But what could it be???
Old 3rd March 2009, 05:55 PM   #30
Zen Mod's Avatar
Magura
well - I meant on that ....... but seems that short circuit between headphones of mine was shorter than usual .......
same question ........ ?
JFET's ready for abuseHide this!Advertise here!
LM3875 abuse vulnerability Puffin Chip Amps 9 14th December 2008 12:46 PM
looking for methods to abuse amps east electronics Solid State 34 31st July 2008 05:39 PM
Reporting an abuse caused Thread Close? jkeny Everything Else 6 20th April 2008 06:50 AM
My wacky budget n00bie 3-way thread. Abuse wanted! Spasticteapot Multi-Way 1 5th January 2007 12:17 AM
sample policy abuse mirlo Parts 1 19th December 2006 05:41 AM
