JFET's ready for abuse
Old 24th February 2009, 10:10 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by Magura
Calophone?
I have seen no mail from you regarding PCB since last weekend??
Magura
calophone - resin used for violin fiddlestick ;
shoot me at >prodanovics@nadlanu.com<
neobee have numerous hickups lately
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th February 2009, 10:15 PM   #12
Magura is offline Magura  Denmark
Magura's Avatar
To tell you the truth, I have no idea.
The flux I use is sure meant for the purpose, but is older than time, so not made under that name anymore.
Mail sent.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th February 2009, 12:21 AM   #13
jupiterjune is offline jupiterjune  United States
A good temperature controlled oven, ramp up to 250C, hold temperature for 30 seconds, let the parts cool off in free air.
Can the Jfets take that heat without damage?
JJ
Old 25th February 2009, 12:51 AM   #14
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Apparently so. You won't see me doing it, though.
Old 25th February 2009, 05:17 AM   #15
EUVL is offline EUVL  Europe
Well said.
Old 25th February 2009, 07:34 AM   #16
Zen Mod's Avatar
Well said.
naah .........
that's working temp in all MetalDanske amps .......
Old 25th February 2009, 10:28 AM   #17
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
I was bored this morning so my nose got the better of me..
I think what choky meant was colophony, see wiki here:
http://en.wikipedia.org/wiki/Rosin
Old 25th February 2009, 11:15 AM   #18
Zen Mod's Avatar
yup .
Old 25th February 2009, 12:21 PM   #19
flg is offline flg  United States
flg's Avatar
I haven't tried any soldering on these JFETs yet but on a daily basis I do such things with similar devices to heavy copper PCBs. Low Temp solder paste is the way to go. For something like the I-Pak I would typically use an air pre-heat stage wich is entended to heat the PCB area up, from the under side, to about 125C over 2-3 minutes. At that point I would put the air pencil to the device and surrounding area from the top side. The paste I use has a Liquidous state at about 140C(Sn42/Bi58). The pencil is ussually set to about 380C but there are alot of variables involved like distance from the device, flow rate, etc. You can watch the paste flow and get molten after about 10-20 seconds. Generally you need a tap on the top center of the device to push down and squash out excess solder and voids and you're done!
Chances are the device would not see over 175C
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 25th February 2009, 03:04 PM   #20
Magura's Avatar
Exactly, this is done on daily basis, nothing new, risky or fancy. This is a well tested, everyday manufacturing principle.
The only news to this, is that it's been done successfully, with relatively low-tech machinery.
.....and naturally the fun of being able to push the limits for the Lovoltech's a bit
Magura
JFET's ready for abuseHide this!Advertise here!
LM3875 abuse vulnerability Puffin Chip Amps 9 14th December 2008 12:46 PM
looking for methods to abuse amps east electronics Solid State 34 31st July 2008 05:39 PM
Reporting an abuse caused Thread Close? jkeny Everything Else 6 20th April 2008 06:50 AM
My wacky budget n00bie 3-way thread. Abuse wanted! Spasticteapot Multi-Way 1 5th January 2007 12:17 AM
sample policy abuse mirlo Parts 1 19th December 2006 05:41 AM
