Aleph 3
Aleph 3
Old 17th April 2003, 07:51 PM   #1
Angel Puerto is offline Angel Puerto  Spain
Default Aleph 3
Hello to all,
I have finished the assembly of an Alehp 3 taking advantage of some heat sink that taenia.
Which the maximum temperature that can reach the heat sink for this assembly is?
A greeting to all.
Angel Puerto.
NOTE: Excuse for my English so bad.
Old 18th April 2003, 06:56 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
I'm not shure if this info is what you are looking for but the rule of thumb for heatsink temperature is not to exceed 50'C. -> You should be able to touch the heatsinks without hurting your hands. The aleph 3 puts out some 200W of heat. This meas your heatsinks should have a total rating of about 0,125 'C/W. Hope this helps.
Mads K
Old 19th April 2003, 04:33 AM   #3
Default Mads
Hello Mads,
Thank you for your comments. But I believe that it warms but of that due that the power supply is bigger to the standard of the Aleph 3 having to support more power the devices.
Angel
Old 26th April 2003, 06:58 PM   #4
Hello Mads,
This is the result 60º with the heat sink that I take advantage.
Vcc + - 33 V. also with a material that I take advantage.
Greetings.
Angel
Old 27th April 2003, 12:17 PM   #5
Mad_K's Avatar
Wow! +/-33V is more like Aleph5! You now have 33*2*4=264W to get rid of.... But 60'C is OK. I believe it will last for a really long time. Happy listening
Mads K
Old 28th April 2003, 05:39 PM   #6
Miles Teg is offline Miles Teg  France
Miles Teg's Avatar
The problem with heatsink : I'm used to see a lot of heatsink without there value of C/W.
I dont' care with the fact I take the biggest heatsink as possible.
But can we determin the dissipation power by the weight of an heatsink ( and of all others part of metal)?
AV: Kali 3 | Centre: Socoa MT30 | Surround: Antigua MT360 | Sub: Triangle Meteor 0.1.5
PS3 | PC | Philips CD723 | Denon AVR-1910 | Projecteur: Epson TW3600
Old 28th April 2003, 05:44 PM   #7
vsr123 is offline vsr123
Talking Calculating Heatsink rating
You can calculate the heatsink rating with its dimensions using the tool in this link
I would also recommend the heatsink article, it makes for good reading.
vsr
Old 29th April 2003, 07:29 AM   #8
Miles Teg's Avatar
Old 29th April 2003, 08:13 PM   #9
Default Mads K
Hello
If I don't remember bad with this tension it gives 50W approximately
When I can a picture of the prototype, I´ll sent you.
Greetings to all.
Angel
Old 7th May 2003, 05:37 PM   #10
Hello to all,
Here the pictures of the prototype are, they lack to add 2 condensers of
150.000 uf.
A thing that was me very well was to put 9 condensers of
2.200 uF Nichicon URZA in parallel with 150.000, in high and sharp means, transparency. Not small condensers of 0,1uF...
Greetings.
Angel.
NOTE: Lament my not well English one.
Aleph 3Hide this!Advertise here!
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 20 7th April 2018 11:04 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 01:13 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
