![]() Referring to Kristijan's drawing above and Nelson's suggestion of "better connectors and wire" in "Top ten ways to a better Aleph?" (Top ten ways to a better Aleph?) I have two questions. In Kristijan's drawing one end of the inputs, both RCA and XLR, is tied to ground on the PCB and the other end is floating. This gives me the impression of some sort of shielded cable. Is this true? And the answer to this question kind of leads into the next question. Choosing from the Percy Audio site what would my fellow forum members suggest as a good upgraded wire? Regards, Dan |
#2 |
I would use sheilded cable in anything over an inch long..... the jumper can be a simple hook up wire...as always keep any power wires away from the signal...hope this helps
Cheers!!The DIRT® |
#3 |
I'm looking through the aforementioned Percy Audio's interconnect wire selection for the inputs. I see where he carries alot of shielded interconnect wire. Also, I'm looking at some of the pure silver "chassis" wire for the outputs.
Regards, Dan |
#4 |
I like to use Kimber TCSS 19ga wire. It is very user friendly and it sounds totally differend from silver plated copper stranded wire, it's very smooth and laid back, while plated copper has more edge.
Cardas wire might be good choice too, but it's enameled and solder pot is almost required to terminate it. I used solid silver wire in my gainclone, but came to conclusion that it's too smooth and lacking in bass. I usually use 19ga. fo signal and 14 ga for power wires. I don't think you need a shield. I never use shielded wire, the chassiss works as shield anyway If you can find solid core copper wire, it may be actually good and cheap solution.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
I'm also still in doubt what best to use for the internal wiring of my Aleph5. eg for connecting the mosfets (p2p).
Some choices: - 1.5 mm silverwire (15 awg), 99.97% pure from intertechnik , costing me 70 euro for 2 meters - 0.65 mm OFC (22 awg) in Teflon (OTA cable from 47lab) costing 7 euro/meter. However is this thick enough?? I could use 2 twisted. - 1.0 mm crystal silverwire (18 awg) vandenHul mcs1000, probably 100 euro/meter - 2.5 mm2 plain copperwire (13 awg) 1 euro/meter The Kimber wire sounds also interresting, but I don't think its sold around here.
Is that all there is? |
#6 |
Studio107.nl is a kimber reseller
#7 | |
#8 |
BTW where do you live in The Hague? I live on erasmusweg near leyweg |
#9 | |
www.partsconnexion.com Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#10 |
I would STRONGLY suggest connecting the chassis to earth!!! Uli
| Internal Wiring... | Tomv | Multi-Way | 1 | 23rd November 2007 08:53 AM |
| Internal amp wiring | Bama Slamma | Solid State | 1 | 2nd November 2006 06:45 AM |
| Which cable to use on Aleph internal wiring? | Sony | Pass Labs | 4 | 25th May 2005 02:05 AM |
| Aleph 5: resistors, caps, internal wiring? | bbakota2000 | Pass Labs | 11 | 19th January 2004 05:01 PM |
| Internal wiring | KenP | Solid State | 18 | 6th December 2002 09:59 PM |
| Page generated in 0.10254 seconds (81.28% PHP - 18.72% MySQL) with 10 queries |
