Nakamichi PA7II Problem
Old 12th February 2009, 06:12 AM   #1
gto127 is offline gto127  United States
Default Nakamichi PA7II Problem
Hello everyone I'm starting work on a Nak PA7II which was worked on by someone else. I've made some initial tests & was curious if you guys might could point me in the right direction on this.
On power on protect lights are lit. I tested power transistors & nothing is shorted. R 136 L & R136R are open. These are 1ohm resistors suppling part of the protect circuit. I was just curious what might cause both resistors to go open at the same time. Since the protect circuits are indepentdant L& R I don't beleive this would have caused them both to go out at same time. Any ideas?
Old 12th February 2009, 10:04 PM   #2
GRollins is offline GRollins  United States
Did you remove the output devices from the circuit to test them--or at least pull the emitter resistor? I suspect you'll find the corresponding transistors to be roasted.
Grey
Old 12th February 2009, 10:20 PM   #3
They tested ok . I would have thought that also. The previous owner may have already replaced them. Just can't figure out why they both went at the same time. The only thing abnormal I can find in protect supply is 26v is 25v & 24v is 22v. I have the associated tiny transistor on order but I think it would have shorted to take out those big resistors.
Old 13th February 2009, 12:32 AM   #4
It's not the small signal part, it's the output device. At a guess, someone shorted the output. Note that protection circuits...aren't. They give you a good feeling that lasts until the output stage smokes, after which you view them with a bit more skepticism.
As for whether the output devices have already been replaced, whether they're good or bad, whether there are other outputs gone, etc...these things can't be determined at a distance. It's up to you.
Grey
Old 13th February 2009, 04:42 AM   #5
I spoke with orig owner & he said that the amp originally ran real hot on right side before going out and when it finally bit the dust that it kept eating output transistors on that side within a minute of replacement. It turns out that transistors had been replaced but prev owner was unaware of bad resistors. I'm hoping to figure why it's eating transistors before replacing resistors. Could possibly bad smoothing caps to out transistors cause this? I have esr meter but's it's not very accurate over 100uf. These are 330uf@ 100v. Thanks for replies.
Old 13th February 2009, 05:02 AM   #6
Nothing for it: You'll have to start at the front end and test every single transistor, including the front end. (When the amp goes, it can send a surge up the feedback loop and hit the front end, the drivers, etc. can take the hit directly.) I'd suggest a very thorough going over. When you've tracked down the dead stuff and replaced it, bring it up on a Variac. A meter, an oscilloscope, a signal source of some kind...it's a pain in the patootie.
Incidentally, you should back the bias down to minimum before starting the thing up.
Grey
Old 13th February 2009, 05:41 AM   #7
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Link to the service manual, i case you don't have it
http://www.audio-circuit.dk/images/s...PA7-pwr-sm.pdf
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 13th February 2009, 05:44 AM   #8
Yes I agree I have my work cut out for me esp with the driver section which I haven't checked. So you think I should abandon the protect circuit/supply with slight voltage off?
Mr Pass you're probably the best amp designer ever but I wish you'd made this one a little simpler. LOL
Old 13th February 2009, 10:05 PM   #9
Once upon a time, there was a book called M*A*S*H. (Yes, Virginia, people read in those days...imagine that! It was later made into a movie, then a TV show...but no one I've spoken to remembers the book. No surprise, I guess.) Blake, one of the doctors, was chastised for obsessively rebuilding a patient's hand...while the patient died of other, far more severe wounds. Beautiful reconstructive surgery, mind you, but it was a case of misplaced priorities.
Methinks you have bigger fish to fry.
Grey
Old 17th February 2009, 04:14 AM   #10
Got a few minutes to work on amp today & noticed main supply to transistors is runnibg 81 volts. Manual states 74v. Does anyone know if manual is correct or if this was misprint?
Nakamichi PA7II ProblemHide this!Advertise here!
Nakamichi Cassette Deck 1.5 problem stevecole Analogue Source 3 8th December 2008 11:07 AM
FS: Nakamichi MB-X and MF-51 whiterabbit Swap Meet 0 27th August 2008 07:28 PM
Nakamichi receiver RE-10, microprocessor problem? box63 Solid State 0 8th September 2006 04:22 PM
Nakamichi LX-3 Problem - Help Bruce Analogue Source 1 18th November 2002 06:43 PM
Nakamichi 420 nickgreek Solid State 5 13th October 2002 09:04 AM
