Old 8th February 2009, 06:47 PM   #1
Default A-40 info needed
Hi!
How many db gain does the A-40 amplifier give?
Aron
Old 9th February 2009, 06:44 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
http://www.passdiy.com/pdf/a40.pdf
MikeW
Old 9th February 2009, 08:22 PM   #3
Hi and thanks Mike.
I do not find any info about gain for the amplifier in the a-40 pdf file. I will use it for bass in a bi-amp project with a F2 for mid/high. The F2 has 15,6db gain so i have to match it to the a-40.
Aron
Old 9th February 2009, 09:20 PM   #4
mjf is offline mjf  Austria
hello.
if i am not totally wrong the voltage gain is round about 24x (or about 28db)
greetings.............
Old 9th February 2009, 09:32 PM   #5
in that case i have some serious mis-match between the amps.
Aron
Old 9th February 2009, 11:28 PM   #6
The one and only
Nelson Pass's Avatar
So adjust the feedback loop to the gain you want.
Old 10th February 2009, 04:55 AM   #7
Will do!
Thanks for your help.
Info needed on 1 sub 1 amp skooter Car Audio 3 27th July 2008 12:25 AM
Tube info needed Marik Tubes / Valves 0 13th February 2008 06:11 AM
Kenwood L-07M info needed please georgehifi Solid State 33 8th January 2008 06:24 PM
Eclipse Info Needed darthfur Car Audio 0 28th May 2006 01:38 PM
LM3876 amp info needed jude ward Solid State 12 9th January 2002 06:08 AM
Page generated in 0.08768 seconds (77.44% PHP - 22.56% MySQL) with 10 queries
