#141 |
Last Friday afternoon I spent an hour or two in the lab trying to find out what caused the amp to fail. Again, it meant to desolder some important components. (which I don't like, and neither does the PCB. some pads have been seriously damaged by the repeated soldering / desoldering).
However, the culprit was found! Z5 failed in parameter drift. The curve tracer showed that for lower zener currents, the voltage drop was much less than specified, and varied a lot with temperature. It also showed some hysteresis effect (probably causing the noise). This caused the diff pair to enter current starvation, and hence, operation ended up far away from the properly balanced point. I replaced the zener and Amp no. 2 is again playing in my workshop /me happy now....
More Power Igor! More Power! |
#142 |
Ah that brings up a point I was going to mention, I have found quite a bit of variance in zener diodes and have had peoblems with this in circuits I have designed for use in my current profession. Maybe this is another item we should test select in the aleph amps.
#143 | |
I'm glad ..........
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#144 | |
The one and only
No voodoo here...
#145 |
Because component failure modes are also of interest to my work environment, I took some time to test the failed zener diode. Perhaps the result is of interest to this community as well...
I put the failed zener on a curve tracer (an invaluable, but also unaffordable piece of equipment when building solid state amplifiers). Attached is two photographs of the display. (This device is probably older than I am). I am using 1N4696 zener diodes (datasheet here) for the constant current source feeding the diff pair. The horizontal axis shows voltage, 1V/div. The vertical axis shows current, 1mA/div. The healthy diode shows a nearly square behaviour and is very stable (as it should be according to the datasheet, minimum zener current is in the order of microamps). The faulty diode is almost like a resistor until there's about 9mA flowing through it. At 4.5mA, the nominal current in the A2, zener voltage is around 5V. Almost half of what it is supposed to be. Furthermore, the resistive part of the "failed" curve was behaving very noisy and even had a hysteresis effect. Combined with a resistor bias, the voltage at the CCS mosfet gate must have been extremely noisy and instable. (perhaps explaining the hissing noise I heard.) As an effect, the diff pair went in starvation, and barely had enough current to achieve proper regulation. I guess Zen Mod had a good feeling from the start
#146 | |
when ? when I wrote "Fugly!" ?
#147 | |
#148 | |
#149 |
This thread reads like a "cliff hanger". Very good.
From the wear and tear on the solder pads of your printed circuit boards, will you continue to deploy them or is it time to place new PCB's in the "twin Towers"? All the best! |
#150 | |
Manu
Manu, masked agent of entropy & ZMs Čiko |
| final aleph 3 sound test | jeapel | Pass Labs | 4 | 16th May 2006 01:22 PM |
| Final Decision: which speaker to build? | Figo | Multi-Way | 0 | 7th December 2003 11:59 PM |
| Aleph ... which one to build ? | thylantyr | Pass Labs | 6 | 22nd August 2002 02:24 AM |
