#11 |
Banned
Hi Nelson
So are you suggesting 15 x 1000uF Elna SIlmics is definitely worth the effort? Or can we get away with a lower capacitance eg 5000uF instead of 15000uF. |
#12 |
Banned
While we are waiting for Nelson to get back to us about C1.
I think we can agree that all other electrolytics on the amp should be Elna Silmics. |
#13 | |
As far as Rs go, I've been using the Caddock MK132 in critical, low power (signal path mostly) spots. I'm of the opinion that resistor distorion may have a few significant factors effecting it. Some, like the actuall material, film, foil, whatever, may not even be advertised but are significant. An important factor you can deal with is the "thermal memory distortion". That is, when in operation, you don't want the signal to be varying the power disipation greatly. Basically that boils down to selecting a component with high enough power dissapation and actual size but, also very low temp coefficient. Most bulk metal foils are the best at around 5-10ppm. In other words, the resistor value does not change as power, or temperature, varies with signal. Just my 2 cents
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#14 | |
#15 | |
![]() In the capacitor tests of Cyril Bateman non-polar electrolytic capacitors showed much lower distortion compared to normal polar electrolytcs, especially whith higher bias voltages across them, so a non-polar Silmic version might potentially be even better, if only one could get those. To my surprise, when browsing through the Silmic datasheet I found the following statement: “For bipolar capacitors, consult with us.” So it looks that they would offer bipolars. Not sure though how they will react when I call them up for my 50 units
Martin Rupp |
#16 | |
The one and only
I think it's worth the effort. The F3 has a very sweet top end, and anything you can do to improve it is worthwhile.
#17 |
Banned
Hi Nelson
Is 15000uF absolutely necessary or can we get by with something less than this value for C1? |
#18 |
Banned
Hi flg,
I tried emailing you about the model, but it seems you have blocked emails for your account. You can also PM me if you want. |
#19 |
Banned
Hi MRupp
If that was the same article I read, then he found he could achieve even better results than bipolars by putting two polarised electrolytcs back-back (ie creating a bipolar with two polarised caps) |
#20 | |
The one and only
rolloff frequency of choice.
| ezDAC v.1.5 Builders Thread | ezkcdude | Digital Line Level | 366 | 14th March 2013 03:31 PM |
| A-X IP Issues (split from Builders thread) | tomchaoda | Pass Labs | 107 | 16th October 2011 02:05 AM |
| one for the box builders | offroadbum | Car Audio | 2 | 11th October 2004 09:19 PM |
