I need help with build my F3
Old 23rd January 2009, 02:27 PM   #1
ak4396 is offline ak4396  Germany
Default I need help with build my F3
Hello,
first sorry for my bad English.
When I adjust the Aleph CCS to 50% ,ca.3,3KOhm for R18 + P2 in Original, and greater the F3 swing. I think I did some wrong in my Layout. Can anybody help me?
I made my own PCB for the F3 because I want learn.
The PCB:
Old 23rd January 2009, 07:38 PM   #2
LS
Old 23rd January 2009, 07:38 PM   #3
SP
Old 23rd January 2009, 07:51 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
When you say the greater the swing, do you mean greater gain and/or
maximum output? This is normal and intended.
Old 26th January 2009, 03:31 PM   #5
Sorry, I mean oscillation not swing.
When I turn the P2 < ca.3k (R18 + P2 < 4,5k) the F3 start to oscillate.
Old 30th January 2009, 02:54 AM   #6
The one and only
At what approximate frequency does it oscillate?
Old 30th January 2009, 07:50 AM   #7
I tried a Capacitor between the B and C of the NPN-transistor in the CCS.
With out this C it oscillates at about 200 kHz and with 1nF at 25 kHz (Aleph CCS at 50%).
With 4,7nF the F3 is completely stabile no meter where the P2 stay.
But the bandwidth gets down.
I think I make a new Layout like Peter Daniel.
Can I change the values of the Feedback Resistors 9k to 6,19k and 47k to 31,6k to increase a little bit the bandwidth with out Problems? I think my pre amp will do this (200Ohm output impedance).
With the Aleph CCS at about 10% (no oscillation) it sounds very good. I hope I can hear the F3 with 50% Aleph as soon as possible.
Old 30th January 2009, 09:51 PM   #8
The one and only
I see that your C19 at .1uf is lower than the 10uf in ZV9. Perhaps
you should try the higher value.
Alternatively try a CE cap instead of a CB cap.
I need help with build my F3Hide this!Advertise here!
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 04:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 03:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Copyright ©1999-2017 diyAudio
