Old 20th January 2009, 05:44 AM   #1
SNOWCRAB's Avatar
Default Help me please, problem with my ALEPH 5
Hello everybody,
For some time I have a problem with my 5 ALEPH
(PCB DESIGN).
The right channel, works with a stifled and distorted sound.
I placed a protective kit speaker
against the DC current that goes into default.
Can someone guide me in my troubleshooting?
Best regards.
Thierry BASSAL.
Old 20th January 2009, 11:58 PM   #2
SNOWCRAB's Avatar
Hi
Last night i made some tests (see original N PASS Schématic)
OFFSET : 35,2 V
Tension between MOSFET Source Résistor
R41 : 0,61 V
R41 : 0,58 V
R42 : 0,60 V
R66 : 0,58 V
R65 : 0,58 V
R64 : 0,58 V
It must be ok
Tension between INPUT MOSFET Résistor
R11 : 4,83 V it must be ok
R14 : 8,40 V (it seems high ?)
Dont you feel there is a problem with Q1 ?
Thierry
Old 21st January 2009, 12:45 AM   #3
MEGA_amp's Avatar
Just to be safe, I'd re-match and install a new pair Q1, Q2. According to Aleph 5 schema, you should have 4-5 volts across R14.
-john
Old 24th January 2009, 01:07 PM   #4
RIP
Looks like Q2 is probably open or bad solder joint. As John said, replace Q1 and Q2 with a new matched pair unless you find a fault in your wiring-soldering.
Bill
Old 25th January 2009, 03:28 PM   #5
SNOWCRAB's Avatar
Hello,
According to pass lab design,
I replaced Q1 - Q 2 - Q 3 with new matched IRF9610.
New tests :
V - : - 39 V
V+ : + 39 V
R11 : 4,78 V
R14 : 5,10 V
R40 : 0,61 V
R41 : 0,59 V
R42 : 0,61 V
R64 : 0,60 V
R65 : 0,58 V
R66 : 0,58 V
Z5 : 8,68 V
OFFSET : 100 mV
The sound is always distorded and stifled.
I am lost ...
Thierry.
Old 25th January 2009, 05:46 PM   #6
RIP
All your measurements look OK. If one channel works compare more component measurements between channels. Check the components values, look for bad solder joints, look for wiring mistakes, check your pinouts on semiconductors.
Bill
Old 26th January 2009, 07:24 PM   #7
MEGA_amp's Avatar
I know it may be trivial; but have you tried swapping the inputs from your source and/or preamp?
problem with R44 on Aleph P 1.7 Stefanoo Pass Labs 15 9th October 2007 12:57 PM
Problem with aleph p 1.7 gabflo Pass Labs 7 2nd September 2006 05:50 PM
Problem with Aleph 2 ppesa Pass Labs 1 31st January 2006 07:44 PM
Aleph 2 problem!Help... nar Pass Labs 14 1st June 2003 03:42 PM
Aleph 5 PSU problem please help? xsnailx Pass Labs 10 4th March 2003 06:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
